Burn in for LSi 7s
Hey guys,
I just purchaseds a pair of LSi 7s from audiogon and I'm curious to how much burn in time you guys have noticed is needed for the mid-woofer to calm down? Fresh out of the package (I'm fairly sure there's not a lot of time put on these, no feet were placed on their bottoms and other telltale signs of little use) I noticed the Vifa XT sounded wonderful, but the mid-woofer is a bit sloppy. Well, rather there seems to be a bump of about 3 decibels at around 150hz to 200hz that then drops to a flatter response for the rest (minus a minor dip around 2.3k - 2.5k that I attribute to the crossover). There is also indication of a bit of boom in the bass as well.
FYI, until my new amp comes in, I'm driving it with a stock t-amp at around 9-10 watts coming straight from a sony cd-player(can't remember model number off the top of my head). The interconnects are from radioshack (I know, I know) and the speaker wire is 16 gauge, none of which runs by power lines or associated and is connected to the lsi's by bare wire.
Is this a matter of more burn in time needed(I've had them on an 80 - 20k sine sweep for about 5 hours, curteousy of WinISD)? Granted, the polks are about 6 inches from the wall, but due to my setup there is not much wiggle room. Ideally, how much breathing room would you give them?
Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
Post edited by Refefer on
Are you taking a near-field measurement or are you measuring from the listening position? Could the bump be part of your room curve?
I felt like my 7's sounded better after breakin. Most will recommend somewhere between 50-100 hours before they are fully broken in.
Most likely, the limited power from the t-amp is the reason they don't sound their best. I beleive there is an inherent spike between 500-800(can't remember the exact frequency) due to the cabinet.
Enjoy your 7's. I've enjoyed mine for quite some time.Tschüss
Zach -
Big difference after about 75 to 100 hours at reasonable volumes.
None needed here. No change in sound quality since I got 'em a long time ago.
The monitors are placed near-field to me 2' - 3' away. I havn't experienced this bump with other monitors I listened to in that spot.Lovin that music year after year.
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
HRT Music Streamer II -
they need to break in, and they will most likely smoke that amp, more time and a better amp will fix the sound.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Ed Zachry, mechanical break in (woofer spider / vc etc) can take 50-100 hours in most cases. Electrical break in (caps especially) can still undergo subtle changes upwards of 800 hours of use in a low-voltage setting like a speaker crossover.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Hmm, thanks. I'll give an assessment in about a week or so then of how they're doing.Lovin that music year after year.
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
