Digital vs Analog SPL
Schris22
Hey Guys,
I know for calibration purposes everyone says use the analog one.
What is the reason for this? I believe digital is 10 dollars more, but besides that is there another reason?
Has there been test that compared the accuracy between the two? Or is it only because of price?
Just wondering
Chris
Just wondering
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Post edited by Schris22 on
I would think it might be easier to measure peaks with a digital one but for just in general I like the analog ones. Something about watching the needle move is almost more interesting than seeing digits change on a display.
Probably more of a preference thing but I'm not quite sure. -
It really doesn't matter, since most use the C-weighted/slow setting on the analog meter. I think that it is a personal preference, and audio has always seemed to favor analog meters over bars and digits on most of the higher end gear.
Why do 90% of speedometers/tachometers use analog? Because its preferred..........HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
It is the measurement circuitry that determines the accuracy of the instrument and that is well before the meter circuit that displays the results.
That being said, the digital display gives you more options for things like peak hold and such and eliminates "parallax" errors. Parallax errors are errrors caused by viewing an analog display at an angle and misreading the position of the needle.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
It's a guy thing! They just like seeing the little arrow bounce around!:p
I have a digital meter it works just fine & is easy to read!:)Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
cfrizz
You are correct. If they made a meter with a even bigger arrow thing to move around we men would buy that one. -
:eek: Seriously?? I was just joking around! WAAAAAAAAAAAAAA!:Dbikezappa wrote:cfrizz
You are correct. If they made a meter with a even bigger arrow thing to move around we men would buy that one.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
