Advice on amp
footwedge
footwedge Posts: 475
edited May 2006 in Electronics
Looking to buy the lsi7s along with the rotel rmb-1075 or 1095. Would the 1095 be overkill? Trying to save a $ where I can while trying to peice meal this sytem. Wow!!! no post after 2 years of lurking/learnig and today I've raised my count to seven.
Thanks in advance.
Post edited by footwedge on
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2006
    Welcome to Club Polk! Why did you wait 2 years to join in the posts?
    Carl
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2006
    Hi Footwedge. No the 1095 will not be overkill. If you can afford it get it!
  • 2+2
    2+2 Posts: 546
    edited April 2006
    Should be fine for the lsi7s. However, if you ever plan on upgrading to more demanding speakers, I suggest you consider the 1095. For instance, 1075 does not drive lsi15s very well. I guess you can always add a larger 2ch amp later.....that is another option....
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • ohskigod
    ohskigod Posts: 6,505
    edited April 2006
    I lurked a while before I posted too :D
    Its hard to overkill anything in the LSi line, they just love the power, even the 7's. the 9's I had loved the 500watts from my carver, only when I tried to get it rediculously loud did it show signs of strain. at all listenable levels, the LSi's showed they appreciated every drop of power they get.
    get the 1095, you'll be fine. for what seems to be a little more, youll have a more versatile amp down the road powerwise. i.e. in better shape if you get...say...bigger LSi's.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • ND13
    ND13 Posts: 7,601
    edited April 2006
    If we ever play golf together, I'll be keeping a watchful eye on you!!!:p ;):)
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • footwedge
    edited April 2006
    I'm so busy doing yard work (completely redoing shrubs and sod) that I don't have time to play like I use too . I do miss the game; and, of course "THE" tournament will start tommorrow; can't wait. If you are ever in LA (lower alabama/mobile), maybe we could tee it up.
    Thanks to all for the advice.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited April 2006
    I'm not sure there is overkill with the LSis.
  • SuperDave
    SuperDave Posts: 168
    edited April 2006
    More is better!
    (within budget)
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Main)
    Denon DVD-1920
    Sony XBR 27"
    BrightHouse DVR
    Polk LSi25 Main
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2006
    LOL... Was wondering if anyone would get his SN...
    Welcome and ditto...
    More later,
    Tour...
    Vox Copuli
  • EricBurg
    EricBurg Posts: 64
    edited April 2006
    I have a 7.1 setup and use the Rotel 1075 for the center and rear surrounds and the Rotel 1080 for the L/R channels. I am running Rti10's, so not as demanding as the Lsi's, but I'm very happy with the sound. If your decision is between those 2 amps, I would go with the 1095. The bigger the better. The 1075/1080 combo would cost you about the same as the 1095, but getting more power means you probably won't have to upgrade any time soon.
    Eric
    __________________
    Pioneer 1015
    Rotel 1080
    Rotel 1075
    Rti10: L/R
    Rti5: C
    Rti6: LS/RS/LSB/RSB
    SVS pb10-isd
  • ND13
    ND13 Posts: 7,601
    edited April 2006
    I used to live in Huntsville. I've played several of the Robert Trent Jones Golf Trail, but not the ones that far south. Maybe someday, though.:)
  • jeffwalter
    jeffwalter Posts: 43
    edited May 2006
    Go with the 1095. I also believe in more power!!!:)
