Advice on amp
footwedge
Looking to buy the lsi7s along with the rotel rmb-1075 or 1095. Would the 1095 be overkill? Trying to save a $ where I can while trying to peice meal this sytem. Wow!!! no post after 2 years of lurking/learnig and today I've raised my count to seven.
Thanks in advance.
Thanks in advance.
Post edited by footwedge on
Welcome to Club Polk! Why did you wait 2 years to join in the posts?Carl
Hi Footwedge. No the 1095 will not be overkill. If you can afford it get it!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Should be fine for the lsi7s. However, if you ever plan on upgrading to more demanding speakers, I suggest you consider the 1095. For instance, 1075 does not drive lsi15s very well. I guess you can always add a larger 2ch amp later.....that is another option....System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
schwarcw wrote:Welcome to Club Polk! Why did you wait 2 years to join in the posts?
I lurked a while before I posted too
Its hard to overkill anything in the LSi line, they just love the power, even the 7's. the 9's I had loved the 500watts from my carver, only when I tried to get it rediculously loud did it show signs of strain. at all listenable levels, the LSi's showed they appreciated every drop of power they get.
get the 1095, you'll be fine. for what seems to be a little more, youll have a more versatile amp down the road powerwise. i.e. in better shape if you get...say...bigger LSi's.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
If we ever play golf together, I'll be keeping a watchful eye on you!!!:p"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
ND13 wrote:If we ever play golf together, I'll be keeping a watchful eye on you!!!:p
I'm so busy doing yard work (completely redoing shrubs and sod) that I don't have time to play like I use too . I do miss the game; and, of course "THE" tournament will start tommorrow; can't wait. If you are ever in LA (lower alabama/mobile), maybe we could tee it up.
Thanks to all for the advice. -
I'm not sure there is overkill with the LSis.
More is better!
(within budget)
SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Main)
Denon DVD-1920
Sony XBR 27"
BrightHouse DVR
Polk LSi25 Main
Polk LSiC Center
Infinity RS1 Rears
Monster THX CablesSuperDave
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
Welcome and ditto...More later,
Tour...
Vox Copuli
I have a 7.1 setup and use the Rotel 1075 for the center and rear surrounds and the Rotel 1080 for the L/R channels. I am running Rti10's, so not as demanding as the Lsi's, but I'm very happy with the sound. If your decision is between those 2 amps, I would go with the 1095. The bigger the better. The 1075/1080 combo would cost you about the same as the 1095, but getting more power means you probably won't have to upgrade any time soon.
Eric__________________
Pioneer 1015
Rotel 1080
Rotel 1075
Rti10: L/R
Rti5: C
Rti6: LS/RS/LSB/RSB
SVS pb10-isd -
footwedge wrote:I'm so busy doing yard work (completely redoing shrubs and sod) that I don't have time to play like I use too . I do miss the game; and, of course "THE" tournament will start tommorrow; can't wait. If you are ever in LA (lower alabama/mobile), maybe we could tee it up.
I used to live in Huntsville. I've played several of the Robert Trent Jones Golf Trail, but not the ones that far south. Maybe someday, though.:)"SOME PEOPLE CALL ME MAURICE,
Go with the 1095. I also believe in more power!!!:)
