going 2.1 (adding the 0.1)
Dizzy_124dvc
Dizzy_124dvc Posts: 27
I have an active sub and a DVD player with no sub output (I used the sub with my shelf system to add the rumble when I watch movies), and I'm planning to get a NAD integrated amp.
Question is, HOW do I feed a signal to the sub? the DVD player has no sub output/mono RCA (unlike the aforementioned shelf system). The sub has high level inputs and outputs though, however, that means I'd need to wire the NAD's two channels to feed the sub first, then wire the outputs to the speakers right? wouldn't this method degrade the quality of the signal, ie pick up noise or reduce warmth in the sound?
Post edited by Dizzy_124dvc on
  • karpiel666
    karpiel666 Posts: 173
    edited May 2006
    As long as the connections on the sub are high quality you shouldent be able to notice a difference. If anything it should tighten up mids and lows with the
    mains not having to produce low frequencies.
    dvd player: samsung DVD-HD850
    receiver: Denon avr5700
    center: polk cs400
    fronts: polk rt800i
    surrounds: Unknown Polk monitor? series.
    sub: svs pb12 isd/v
    tv: 46 inch samsung
  • Zen Dragon
    Zen Dragon Posts: 501
    edited May 2006
    You should be fine. When you set the sub crossover it acts like a filter. It sends the low frequencies that the sub needs to the sub amplifier and passes everything above the crossover frequency back through to the speakers.
    As Karpiel has stated, it relieves the NAD amp from having to drive the lower frequencies which puts the greatest strain on an amplifier as that is where the impedance can really dip and demand the most current from your amp.
    Without having to drive the low frequency high current peaks the NAD amp can put more umph into the mids and highs.
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
  • adam2434
    adam2434 Posts: 995
    edited May 2006
    Here's another recent thread about adding a sub for 2 ch:
    http://www.polkaudio.com/forums/showthread.php?t=40334
    You will only relieve your NAD of bass frequencies if the sub has a high pass filter on the speaker outs. Very often, a sub's crossover is only a low pass filter for the sub, and therefor, the speaker outs run full range.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • Early B.
    Early B. Posts: 7,900
    edited May 2006
    Yes, it will affect the quality of the signal, but whether or not it makes a difference is the issue. In your case, probably not.
    "God grooves with tubes."
