What CDP would you buy?
steveinaz
If you had $1600, what Redbook CD Player would you buy? (new, street price)
Post edited by steveinaz on
Do I have to spend $1600?
I might get the Shanling CDP which I believe sells for around $1500.
Reviews are lukewarm and folks say it isn't worth the price but boy does it look amazing!!! It sure is a great conversation, show-off piece.
http://www.shanling.com/Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes) -
Arcam CD-192
Musical Fidelity A3.5"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Ditto on the Shanling. It could sound no better than my POS DVD player, but it looks totally rad.
shack wrote:Arcam CD-192
Musical Fidelity A3.5Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
you can get a modded Jolida for less than that too, never heard the modified ones, but there is supposedly a significant difference from the stock one. me? I'm happy with stock, for nowLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Shizelbs wrote:Ditto on the Shanling. It could sound no better than my POS DVD player, but it looks totally rad.
That bad huh??! :eek:
tryrrthg - I second Rega. They look quite ugly (cheap) but they sound amazing. The Rega Apollo at $1K is a steal (IMHO)Distant Dream - A New Beginning
crazy wrote:That bad huh??! :eek:
I have heard good things from them. When I get caught up on my audiophile vocabulary I intend on giving a summary of my experence so far.
I can say yes they sound amazing.polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Might be worth it to go used and get the A5- I know the question was new/street, but the A5 is a whole different league- tube output stage, uber low jitter, 192khz vs 96khz sampling...
Having heard them both, the A5 is worth it.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
