Which Denon
simphiwes
WHich Denon do you guys think is suitable for the Rti8 seeing the Pioneer sub elite models arent wort it. i will be adding a power amp later but denon does not seem to make any, i didnt see any on the website either? Help!
(((((STEREO)))))
System 1(complete)
Front: Rti8
Intergrated: Valve Audio Epsilon
CD Player: Xindak Muse Delux 1.0
Media Player: Mede8er MED 200
Behringer DAC
System 1(complete)
Front: Rti8
Behringer DAC
Post edited by simphiwes on
Hi Simphiwes. Denon does not make separate power amps but there are plenty of other makers of better separate amps to choose from.
Denon makes a good product, just pick the one that has all the features you want & make sure it has preouts & you will be all set!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Hi Simphiwes,
I have Denon AVR3806. It has all the bells and whistles for audio/video. As cfrizz said make sure you get the one with preouts. A month ago I have added B&K AV5000 5 channel amp. I have bi-amped my front Rti8s and running the centre straight from the B&K amp.
The Rti8 were a little on the bright side (IMO) with the Denon alone. After I added B&K amp the silk dome tweeters mellowed down on 8s and it sounds sweet. When I say tweeters are bright I mean with music only.
Most standalone amps with reasonable power supply will run your 8s nicely.
Gator
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
5805. If I don't know your needs other than to run the 8's and your budget, I can't really direct you in the right direction.Never kick a fresh **** on a hot day.
