Srs 2.3tl
min888
min888 Posts: 42
edited May 2006 in Vintage Speakers
Hey guys I think this is a good deal if u're looking.
http://www.craigslist.org/sby/ele/155678402.html.
These are not mine just happens to see the ad. Do you guys think these are better than my SRS, the original?
Post edited by min888 on
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2006
    The 2.3 tL's are nice. I would keep the SRS's if I were you!
    Carl
  • Emlyn
    Emlyn Posts: 4,714
    edited April 2006
    I'd say the 2.3TL's, compared to the original SDA-SRS, are better overall only if no tweeter upgrades are done. If the SDA-SRS and 2.3TL's have the improved silk dome tweeters, the two are comparable but have different strengths, but one's not better overall than the other. The cabinet structure is more rigid with the 2.3TL's. One potential benefit with the 2.3TL's over the original SDA-SRS is the ability to use a true dual-mono amp or monoblocks with the common ground interface cable.
  • francis1967
    francis1967 Posts: 161
    edited May 2006
    What is the part number for the silk dome tweeter replacement for the SL2000?
  • schwarcw
    edited May 2006
    RD-0194. Polk Customer Service will ask you which tweeter you are replacing, so you can't go wrong!
    Carl
