Srs 2.3tl
min888
Hey guys I think this is a good deal if u're looking.
http://www.craigslist.org/sby/ele/155678402.html.
These are not mine just happens to see the ad. Do you guys think these are better than my SRS, the original?
Post edited by min888 on
The 2.3 tL's are nice. I would keep the SRS's if I were you!Carl
I'd say the 2.3TL's, compared to the original SDA-SRS, are better overall only if no tweeter upgrades are done. If the SDA-SRS and 2.3TL's have the improved silk dome tweeters, the two are comparable but have different strengths, but one's not better overall than the other. The cabinet structure is more rigid with the 2.3TL's. One potential benefit with the 2.3TL's over the original SDA-SRS is the ability to use a true dual-mono amp or monoblocks with the common ground interface cable.
What is the part number for the silk dome tweeter replacement for the SL2000?
RD-0194. Polk Customer Service will ask you which tweeter you are replacing, so you can't go wrong!Carl
