crossovers
bannanawho
bannanawho Posts: 2
edited May 2006 in Vintage Speakers
Where can I get crossovers for Monitor 7?
Post edited by bannanawho on
  • dan152
    dan152 Posts: 27
    edited April 2006
  • BobMcG
    BobMcG Posts: 1,585
    edited April 2006
    You'll see them listed in the Polk parts list but I don't think they've been available for years.
  • Zen Dragon
    Zen Dragon Posts: 501
    edited April 2006
    Just curious how you determined the crossover was bad?
    Also do you know how it became damaged. Generally crossovers are fairly resilient and you may want to understand what happenned to it before you pop another one in.
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
    F1nut Posts: 51,778
    edited April 2006
    Dan152,
    Those parts haven't been available for years.
  • dan152
    dan152 Posts: 27
    edited April 2006
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2006
    What model Monitor 7 do you have?
    F1nut Posts: 51,778
    edited April 2006
    He didn't say what problem he is having, but the most common failure would be the caps, which could result in distortion or no sound at all. The solution would require replacing the caps. I would recommend replacing all of them and you might as well replace the resistor(s) while you're at it.
  • dan152
    dan152 Posts: 27
    edited April 2006
  • dan152
    dan152 Posts: 27
    edited April 2006
    __________________
    F1nut Posts: 51,778
    edited April 2006
    Every crossover is different. The values can be found on the components or you can get a schematic from Polk.
  • dan152
    dan152 Posts: 27
    edited April 2006
    F1nut Posts: 51,778
    edited April 2006
    Dan,
    Which model do you need info on?
  • ESavinon
    ESavinon Posts: 3,067
    edited April 2006
    I have a pair of monitor 7 crossovers available if you need them.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • dan152
    dan152 Posts: 27
    edited May 2006
    ___________________
  • dan152
    dan152 Posts: 27
    edited May 2006
    _____________
  • ESavinon
    edited May 2006
    They might be similar in design or the same. Call ken at customer service and ask.
    F1nut Posts: 51,778
    edited May 2006
    Dan,
    I don't have any info on that model, sorry. As Esavinon suggested, contact Polk.
    heiney9 Posts: 25,433
    edited May 2006
    Dan,
    Check this thread. The original Monitor series are in the 1st post. You'll have to click on each and enlarge it to see which model it's for. The info is listed in the legend of the schematic.
    http://www.polkaudio.com/forums/showthread.php?t=38755
    Good luck. This will give you the values of the parts so you can replace the old parts on the same board.
  • dan152
    dan152 Posts: 27
    edited May 2006
    ___________________
  • dan152
    dan152 Posts: 27
    edited May 2006
    __________________
    F1nut Posts: 51,778
    edited May 2006
    Dan,
    CALL, do not email.
    edited May 2006
    It appears that both schematics are the same. They both use the same active drivers and all the values of inductors, resistors and capacitors are the same and in the same position. However, it's always good to check with Ken in CS just to make 100% sure.
  • dan152
    dan152 Posts: 27
    edited May 2006
  • dorokusai
    edited May 2006
    Aren't you glad you didn't waste time upgrading your crossovers? Simple troubleshooting usually works things out.
  • dan152
    dan152 Posts: 27
    edited May 2006
    You're right. Too bad somebody didn't come along and offer help in the meantime. :confused:
    F1nut Posts: 51,778
    edited May 2006
    What are you talking about??? The only general questions you asked were, "How about offering some helpful info on determining the symptoms of a failed cross-over or how to repair such." and "Any techinical info on the cap and resister sizes to use in such a repair?" From those we're suppose to read your mind that you have a problem?
    Next time try explaining exactly what problem you are having and with what product.
    As for crossover upgrades, not repairs....well, the only way to know if they improve things is to try it for yourself. Some folks don't believe in them, others do. Besides that, no one said anything about upgrading, just repairing and it looks like help was offered in that area.
  • TroyD
    TroyD Posts: 13,124
    edited May 2006
    Been an interesting crowd, lately.
    BDT
    edited May 2006
    BDT
    Yep, free, friendly advice sure gets a lot of scrutiny lately. Words on a page can take a different meaning, but he zinged F1 and then his most recent comment. Question asked and answered, what more does the guy want? :rolleyes: :rolleyes: .
  • dorokusai
    edited May 2006
    I thought he received as much help as could have been given.
    As a side note, I believe in crossover upgrades.
