Whats the difference between RT/FX and LS/FX surrounds?
trubluluc
I have had LS/FX surrounds, but have never seen the RT/FX surrounds.
Anyone know what is the difference?
-Luc
-Luc
Post edited by trubluluc on
RT/FX have a single 5 1/4 inch mid and 2 1" Tri-Lam Tweeters where as you know the LS/FX have dual 4 1/2 mids and 2 1" TLs.
The RT model is quite a bit larger too.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I hadn't even heard of the RT/FX before.
Would you say the sound quality is comparible to the LS/FX?
I was thinkin of using them as surrounds in a SDA driven theater.
I know the LS/Fx go for about $125-$150 what do you think a reasonable price would be for the RT/FX?
thanks,
-Luc -
I think the RT f/x's were the original SRT surrounds... (anybody?)
RT f/x ebay range is $100 - $120. $80 is the lowest I've seen and $150 the highest. Black or white same price range.
This in contrast to the LS f/x where the white go for less than the black.
While the RT's are a bit bigger than the LS's, they're not all that much bigger. The f/x 1000's are the big boys of the Polk surrounds.More later,
Tour...
Vox Copuli
Good info. there bud.
-Luc -
You're welcome... now I just need to decide if I want to sell you my RT's. God knows I need to start moving some of my holdings out of here...More later,
Tour...
Vox Copuli
Here's what I have on these:
RT/FX
MSRP: $449/pair
Overall Frequency Reponse: 40Hz-25kHz
-3dB limits: 50Hz-24kHz
Recommended Amplification: 50-100 WRMS
Efficiency: 89db
Nominal Impedance: compatible with 8 ohm outputs
Inputs: 5-way binding posts
Radiation Pattern: Switchable, dipole / bipole
Enclosure Type: Vented
Driver Complement (all shielded)
2 x 1" (25mm) Dynamic Balance® dome tweeters
1 x 5.25" (133mm) Dynamic Balance® driver
Cabinet Dimensions
10" H x 8.5" W x 6.75" D (at base of cabinet)
25.4cm H x 21.6cm W x 17.2cm D (at base of cabinet)
Weight: 17 lbs / 7.73kg
SRT/FX
-3db Frequency Response Limits: 90Hz-25kHz
Power Handling: 100 Watts RMS
Nominal Impedance: 4 ohms
Enclosure Type: Sealed tapered cabinet
Driver Complement
Mid/woofer 2 each 4 1/2" (11.4cm) Dynamic Balance® Drivers
Tweeter 2 each 1" (2.5cm) Dynamic Balance® Tri-laminate dome tweeters
Cabinet Dimensions
11" H x 6 1/2" W x 9" D (at base of cabinet)
27.4cm H x 16.5cm W x 16.5cm D (at base of cabinet)
Weight: 18 lbs. / 8.53kg
LS/FX
MSRP: $599.95 pair
Enclosure Type: Sealed and tapered
Driver Complement
Mid/woofer 2 each 4 1/2" (11.4cm) Dynamic Balance® drivers
Cabinet Dimensions
27.94cm H x 16.5cm W x 16.5cm D (at base of cabinet)
My notes:
SRT/FX
- knob type dipole/bipole switch
- mid-woofer cone has hexagonal pattern
- gold binding posts
? did this come with the Tri-laminate dome tweeter available in different shades ...
? almost identical to LS/FX ...
RT/FX
- flip type dipole/bipole switch (have seen knob switch also)
- mid-woofer cone is round w/o pattern
- nickel binding posts
- all drivers shielded (have seen non-shielded also)
SDA surround speakers (vintage recommendations)
- FX/1000: All SDA-SRS, SDA-1, SDA -1(A-C), LS90, RTA-15
- FX/500: SDA-2 (all versions), SDA-CRS, RTA-15, RTA-12, RTA-11, RTA-8, Monitor 10 and Monitor 12, LS70, LS50
- RT/FX: SDA-CRS, RTA-8, Monitor 7, S-10, LS50 -
Wow, now that's thorough research.
It's like reading a chapter in Polk and Wagnalls.:)
-Luc -
Is that another of DarqueKnight's publications?trubluluc wrote:It's like reading a chapter in Polk and Wagnalls.:) -LucMore later,
Tour...
Vox Copuli
The original SRT surrounds were monsters.
They had four 5.25" drivers and two 1" tweeter. They were in theory true "SDA Surrounds".
Polkwannabe has a pair in his SRT setup.
They are very large.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Per the Polk specs listed, Polk65 is off on the response of the LS/fx and SRT/fx: The -3 response is 50-24k, not 90-25k. 50 is pretty dang low for those little boxes. Is that realistic?
Polk65, why do you list the RT/fx for the surround recommendation for the LS70 and LS50? Would not the LS/fx be better matched, since it uses the same tweeter?
What tweeter do the f/x500 and 1000 surrounds use? The Clubpolk page doesn't list the fx surround parts. -
Hopefully someone else with information will chime in. Keep in mind that many models often used superceded drivers so they will vary over the years of production.
The specs I listed for the SRT/fx (photo6) comes from Polk Audio's SRT manual page 6 and notes from the forum. Officially recommended surrounds change from time to time. I believe the answer to your question is that the later RT/fx came with the tri-laminate tweeter.
There are two versions of the RT/fx that I am aware of. The early version (photo5) came with a dynamic balance (black) tweeter. A later version used the tri-laminate (silver) tweeter (photo4).
I believe the larger SRT/fx surrounds (photo3) were a later version. The smaller surrounds are described in the manual and I was told that the large surrounds were available with the SRT controller as an add-on a package. -
Correct.
My RT f/x's have the tri-lam tweeter.... same as my LS f/x's.More later,
Tour...
Vox Copuli
My LS/fx manual lists the -3 response as 90-25k, overall of 60-26k. I guess the web page is wrong(?)
Setting the sub crossover at the THX 80 Hz would then leave a pretty big gap for the surrounds, eh? -
soiset wrote:My LS/fx manual lists the -3 response as 90-25k, overall of 60-26k. I guess the web page is wrong(?)
I wouldn't run either of the surrounds mentioned on large, they just aren't built for full range use. The 80 hz crossover is fine.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
