Whats the difference between RT/FX and LS/FX surrounds?
trubluluc
trubluluc Posts: 2,067
edited May 2006 in Vintage Speakers
I have had LS/FX surrounds, but have never seen the RT/FX surrounds.
Anyone know what is the difference?
-Luc
Post edited by trubluluc on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2006
    RT/FX have a single 5 1/4 inch mid and 2 1" Tri-Lam Tweeters where as you know the LS/FX have dual 4 1/2 mids and 2 1" TLs.
    The RT model is quite a bit larger too.
  • trubluluc
    edited April 2006
    I hadn't even heard of the RT/FX before.
    Would you say the sound quality is comparible to the LS/FX?
    I was thinkin of using them as surrounds in a SDA driven theater.
    I know the LS/Fx go for about $125-$150 what do you think a reasonable price would be for the RT/FX?
    thanks,
    -Luc
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2006
    I think the RT f/x's were the original SRT surrounds... (anybody?)
    RT f/x ebay range is $100 - $120. $80 is the lowest I've seen and $150 the highest. Black or white same price range.
    This in contrast to the LS f/x where the white go for less than the black.
    While the RT's are a bit bigger than the LS's, they're not all that much bigger. The f/x 1000's are the big boys of the Polk surrounds.
    More later,
    Tour...
    Vox Copuli
  • trubluluc
    edited April 2006
    Good info. there bud.
    -Luc
  • Tour2ma
    edited April 2006
    You're welcome... now I just need to decide if I want to sell you my RT's. God knows I need to start moving some of my holdings out of here...
    More later,
    Tour...
    Vox Copuli
  • Polk65
    Polk65 Posts: 1,405
    edited April 2006
    Here's what I have on these:
    RT/FX
    MSRP: $449/pair
    Overall Frequency Reponse: 40Hz-25kHz
    -3dB limits: 50Hz-24kHz
    Recommended Amplification: 50-100 WRMS
    Efficiency: 89db
    Nominal Impedance: compatible with 8 ohm outputs
    Inputs: 5-way binding posts
    Radiation Pattern: Switchable, dipole / bipole
    Enclosure Type: Vented
    Driver Complement (all shielded)
    2 x 1" (25mm) Dynamic Balance® dome tweeters
    1 x 5.25" (133mm) Dynamic Balance® driver
    Cabinet Dimensions
    10" H x 8.5" W x 6.75" D (at base of cabinet)
    25.4cm H x 21.6cm W x 17.2cm D (at base of cabinet)
    Weight: 17 lbs / 7.73kg
    SRT/FX
    -3db Frequency Response Limits: 90Hz-25kHz
    Power Handling: 100 Watts RMS
    Nominal Impedance: 4 ohms
    Enclosure Type: Sealed tapered cabinet
    Driver Complement
    Mid/woofer 2 each 4 1/2" (11.4cm) Dynamic Balance® Drivers
    Tweeter 2 each 1" (2.5cm) Dynamic Balance® Tri-laminate dome tweeters
    Cabinet Dimensions
    11" H x 6 1/2" W x 9" D (at base of cabinet)
    27.4cm H x 16.5cm W x 16.5cm D (at base of cabinet)
    Weight: 18 lbs. / 8.53kg
    LS/FX
    MSRP: $599.95 pair
    Enclosure Type: Sealed and tapered
    Driver Complement
    Mid/woofer 2 each 4 1/2" (11.4cm) Dynamic Balance® drivers
    Cabinet Dimensions
    27.94cm H x 16.5cm W x 16.5cm D (at base of cabinet)
    My notes:
    SRT/FX
    - knob type dipole/bipole switch
    - mid-woofer cone has hexagonal pattern
    - gold binding posts
    ? did this come with the Tri-laminate dome tweeter available in different shades ...
    ? almost identical to LS/FX ...
    RT/FX
    - flip type dipole/bipole switch (have seen knob switch also)
    - mid-woofer cone is round w/o pattern
    - nickel binding posts
    - all drivers shielded (have seen non-shielded also)
    SDA surround speakers (vintage recommendations)
    - FX/1000: All SDA-SRS, SDA-1, SDA -1(A-C), LS90, RTA-15
    - FX/500: SDA-2 (all versions), SDA-CRS, RTA-15, RTA-12, RTA-11, RTA-8, Monitor 10 and Monitor 12, LS70, LS50
    - RT/FX: SDA-CRS, RTA-8, Monitor 7, S-10, LS50
  • trubluluc
    edited April 2006
    Wow, now that's thorough research.
    It's like reading a chapter in Polk and Wagnalls.:)
    -Luc
  • Tour2ma
    edited April 2006
    trubluluc wrote:
    It's like reading a chapter in Polk and Wagnalls.:) -Luc
    Is that another of DarqueKnight's publications?
    More later,
    Tour...
    Vox Copuli
    VR3 Posts: 29,427
    edited April 2006
    The original SRT surrounds were monsters.
    They had four 5.25" drivers and two 1" tweeter. They were in theory true "SDA Surrounds".
    Polkwannabe has a pair in his SRT setup.
    They are very large.
  • soiset
    soiset Posts: 724
    edited May 2006
    Per the Polk specs listed, Polk65 is off on the response of the LS/fx and SRT/fx: The -3 response is 50-24k, not 90-25k. 50 is pretty dang low for those little boxes. Is that realistic?
    Polk65, why do you list the RT/fx for the surround recommendation for the LS70 and LS50? Would not the LS/fx be better matched, since it uses the same tweeter?
    What tweeter do the f/x500 and 1000 surrounds use? The Clubpolk page doesn't list the fx surround parts.
  • Polk65
    Polk65 Posts: 1,405
    edited May 2006
    Hopefully someone else with information will chime in. Keep in mind that many models often used superceded drivers so they will vary over the years of production.
    The specs I listed for the SRT/fx (photo6) comes from Polk Audio's SRT manual page 6 and notes from the forum. Officially recommended surrounds change from time to time. I believe the answer to your question is that the later RT/fx came with the tri-laminate tweeter.
    There are two versions of the RT/fx that I am aware of. The early version (photo5) came with a dynamic balance (black) tweeter. A later version used the tri-laminate (silver) tweeter (photo4).
    I believe the larger SRT/fx surrounds (photo3) were a later version. The smaller surrounds are described in the manual and I was told that the large surrounds were available with the SRT controller as an add-on a package.
  • Tour2ma
    edited May 2006
    Correct.
    My RT f/x's have the tri-lam tweeter.... same as my LS f/x's.
    More later,
    Tour...
    Vox Copuli
  • soiset
    soiset Posts: 724
    edited May 2006
    My LS/fx manual lists the -3 response as 90-25k, overall of 60-26k. I guess the web page is wrong(?)
    Setting the sub crossover at the THX 80 Hz would then leave a pretty big gap for the surrounds, eh?
  • Dennis Gardner
    edited May 2006
    I wouldn't run either of the surrounds mentioned on large, they just aren't built for full range use. The 80 hz crossover is fine.
