PSW100 Wattage
death734
i just got a psw100 from a friend, and i was wondering how many watts is it?
does anyone know the frequency responce for it?
is there any websites that list specs for it?
but mainly im just curious about the wattage.
Post edited by death734 on
Is it a Polk product? If so double check your model number. Polk makes similiar model numbers PSW10, PSW120, PSW150, PSW1000. Info on Polk subs can be found from the link near the top of the page for Home audio.
http://www.polkaudio.com/homeaudio/index.php
Also in the older product link from the left side bottom of the first link
http://www.polkaudio.com/search/older.php
If your unit is a model PSW100 it is likely a product made by audiosource.
http://www.home-technology-store.com/detail.aspx?ID=2135The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
yeah its by polk
i guess its a discontinued model, but right on the back it says polk audio psw100 -
Hmmm. Can't find any info on the unit, only a single unit on EBAY that has been up for aution 3 times with no buyers. Perhaps a member here has had that unit and can help.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
Did you try searching the forums here?? http://www.polkaudio.com/forums/showthread.php?t=19491&highlight=psw100
I'll add to my previously posted specs, also from the original manual: -3db limits: 31Hz-150Hz. So yes.. meaningful output at 22Hz is wishful thinking. I recently tested it using a PC-based audio generator and it (or my own hearing) seemed to peter out in the high 30s.System: PS Audio HCA-2, PCA-2 + HCPS, Acoustat Model 2+2.
Tweaks: Behringer DEQ2496, SRC2496, SU9920.
Friends don't let friends drive cones -
* High Velocity Compression Drive Technology
* 8 Inch Driver
* 65 Watt Amplifier
* Overall Frequency Response : 22 ~ 200 Hz
* Lower -3 dB Limit : 31 Hz
* Upper -3 dB Limit : 150 Hz
* Adjustable Low Pass Filter : 50 ~ 150 Hz
* Polarity Adjustment : 0 and 180 degrees.
* Produced from 1994 to 1996
* retailed for $550.00PolkFest 2012, who's going>?
thank you
