Hello
unknown
Hello fellow polkies. I have been lurking in this forum for a while now and from this forum is where I got a lot of my home theater ideas on the budget side.
Anyways, my quest for a decent HT equipment has led me to the following equipments through the years of lurking at several audio/video sites (this one includint):
Infocus 4805 for display
Fosgate Audionics FAP T1+ for the pre-pro
Outlaw Audio 7100 7 channle amp
Onkyo Universal DVD player
LSi15 front
LSiC center
LSi7 sides
LSiFx rears
I do not play my system at reference levels and I should say that it is OK for now. And from reading a lot of people's posts re:LSi speakers, they need to be juiced up to at least 200 watts at 4 ohms.
Now, I have been looking for a budget amp (<$1K) at audiogon and ebay to rectify this issue. And through my search, I saw this amp at Audio Advisor for $799, it is made by Boston Acoustics, the model is A7200 and its supposed to be 120 watts per channel and as an added bonus, it has a dual torroidal transformer.
Anways, do you guys know of this amp? How do you guys think this will compare to the Outlaw 7100?
Thanks in advance for your input.
-unk
LSi15 front
LSiC center
LSi7 sides
LSiFx rears
-unk
Post edited by unknown on
You're OK with the Outlaw. No need to change out what you have. However, if you decide to buy another amp, it should be at least 200 wpc into 8 ohms. That'll give you more than enough headroom. Going from 100 wpc to 120 wpc isn't worth doing, IMO.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Welcome to the boards. I cannot help you with the amps since I have only owned the outlaw. I can say that I have been happy with it and have had no complaints.
I do have a question for you though. Why did you decide to use your best sound diffusers (LSiFx) for the rears instead of the sides?
Again welcome to Club Polk. Very nice system you have put together!Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
The Outlaw is a great amp. A Rotel or Parasound will also fit your budget (used).
Welcome to the Forum!Carl -
Welcome!
What size screen you shooting that 4805 on?If...
Ron loves a film = don't even rent. -
wow nice system
I snagged an Adcom 5500 and it sounds great with my Lsi's. It is 200wpc@8 ohms and 350wpc@4 ohms. Very smooth sound.
SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Main)
Denon DVD-1920
Sony XBR 27"
BrightHouse DVR
Polk LSi25 Main
Polk LSiC Center
Infinity RS1 Rears
Monster THX CablesSuperDave
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
I can also vouch for the Adcom. Very clean and has worked well with my Polk monitors.
