bi-wiring help for monitor 50
shantanu
shantanu Posts: 2
Hello,
I would like to bi-wire my monitor 50s. I have a Yamaha AV receiver that has a speaker A, B, A+B selector option.
From the Monitor catalogue diagram (for bi-wiring), it looks like both pairs of cables for bi-wiring each unit is coming out of the same terminal (A or B).
Is that how it should be done?
Or should I run one cable (say to the Tweeter) from the A terminal, and the other (to the Mid/Woofer) from the B terminal. And then set the setting on the AVR to A+B?
Also, my AVR has a IMPEDENCE SELECTOR switch. This is what the manuals says:
LEFT -
(i) if you use one set of speakers (A or B), each speaker should be 4 ohms or higher)
(ii) if you use two sets (A+B), the impedence of each speaker must be 8 ohs or higher.
RIGHT -
(i) if you use one set of speakers (A or B), each speaker should be 8 ohms or higher)
(ii) if you use two sets (A+B), the impedence of each speaker must be 16 ohs or higher.
Right now (without bi-wiring) the switch is set to RIGHT.
If I should bi-wire my Monitor 50 through A+B, should I move the switch to LEFT?
Thanks.
Post edited by shantanu on
  • ronnie
    ronnie Posts: 150
    edited April 2006
    What Reciever Do You Have, SOUNDS LIKE A OLDER ONE
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Yamaha CD685 cd changer
    Yamaha Dvd c950 dvd changer
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    Polk RTi6 (surround and surround back)
    Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
    WindyWillys cooling fan (works great)
    Mitsubishi 52in big screen
    blue jeans cables
    AR interconnects
  • shantanu
    shantanu Posts: 2
    edited April 2006
    Hey,
    Thanks for replying. Yes I have a realy old Yamaha. More of a hand-me-down. It is a rx-v450
  • ronnie
    ronnie Posts: 150
    edited April 2006
    when they tell you about ohms i think its usually a heating issue....run a channel to the top posts of the speakers and b channel to the bottom. keep a+b on and set it to 4ohms or higher... now im not a pro at this stuff but i think this is the correct way.......and remeber to take off the jumpers from the speakers
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2006
    Either way will work fine; take both leads off "A" or use A+B. Probably easier to use A+B if your wire is fat....
  • jayman_1975
    jayman_1975 Posts: 672
    edited May 2006
    i really doubt it'll sound better that just wiring it normally..i tried it on a panny i had and it actually degraded the sound quality. I Don't think that you are actually doubling your power when running off a and b simultaneously. But just hook it up and see for yourself..i could be wrong...it has happened before.
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • MSALLA
    MSALLA Posts: 1,602
    edited May 2006
    I'm not sure on this but I think both wires should go to A or B. If you use both you will be at 4 ohms and you might not be stable at 4 ohms.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Willow
    Willow Posts: 11,231
    edited May 2006
    If you have not bought or can return the xtra cable do so. if anything, replace the metal jumpers with some speaker cables and you're good to go.
    as for the impedance button I say leave it where it is now.
