Mechanic Help in NoVA Area?
MrBuhl
Hey All -
Anyone have a good mechanic they trust in the Northern, VA (Sterling, etc) area? Need some help with the wife's car before she sells the SDA's to pay for new A/C compressor & condensor! :eek:
Thanks for any help
Ed
Thanks for any help
Ed
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
What type of car, year, problem? May be simple fix.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Do you listen to Pat Goss, ala 106.7 WJFK, on the weekends Mr. Buhl?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I know its not in Sterling but my mother and I have entrusted all of our car repairs to the same mechanic for the past 20 years...ask for Tony of Professional Auto Care in Woodbridge, VA. He provides quality and professionalism at a very reasonable price. I live in Front Royal, VA (over an hour away) and I still take my cars there to be serviced!2 Channel Rig
Source 1 - Apple TV
Source 2 - Parasound D3 Universal Player
Source 3 - Parasound Tuner T3
Pre-amp - Parasound HALO P3
Amplifier - Parasound HALO A21
Speakers - Martin Logan Vista
Power Conditioning - Panamax M5100-EX -
Hey - Thanks for the tips fellas!
98 Mazda Protege with 105K on her. Fried clutch in the A/C Compressor banging struts are bottoming out. (A/C no longer produced in two piece - must buy whole compressor I have been told) and it does need struts all around admitedly.
I am a fair shade tree mechanic (did brakes, shocks, full leaf sping suspension kit with lift and transfer drop on my Jeep by myself) so I think I could do the struts given the time - but they want $2200 for everything here and hell, the retail blue book isn't even that on the whole car!
I know the A/c will be top dollar - I am just plain pissed to be told that $220 worth of struts (of course I checked) are going to cost me $1200 including parts to install. BULLS_ _ T! That's like the $600 brake job scam.
OK - Rant is over now.
Thanks for the help - keep em coming if anyone has experience with the struts or a reasonable mechanic.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
dorokusai wrote:Do you listen to Pat Goss, ala 106.7 WJFK, on the weekends Mr. Buhl?
No - What time is he on? Will check out.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Goss' Garage with Pat Goss on WJFK
NEW: For Live Streaming... http://1067freefm.com/pages/1851.php
Every Weekend
Saturday: 12 - 4 pm
Sunday: 11 am - 3 pm
http://www.goss-garage.com/CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
May want to check with your local parts store, Auto Zone, etc, they may have access to the Junkyard database. Swap it out, new O-rings, pull a vac., put $12 worth of R134a and you are good to go.>
Polkersince85 wrote:May want to check with your local parts store, Auto Zone, etc, they may have access to the Junkyard database. Swap it out, new O-rings, pull a vac., put $12 worth of R134a and you are good to go.
Hmmmm... you may be on to something here. Hadn't thought about used parts, thanks!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
