Mechanic Help in NoVA Area?
MrBuhl
MrBuhl Posts: 2,419
edited April 2024 in Clubhouse Archives
Hey All -
Anyone have a good mechanic they trust in the Northern, VA (Sterling, etc) area? Need some help with the wife's car before she sells the SDA's to pay for new A/C compressor & condensor! :eek:
Thanks for any help
Ed
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited April 2006
    What type of car, year, problem? May be simple fix.
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2006
    Do you listen to Pat Goss, ala 106.7 WJFK, on the weekends Mr. Buhl?
  • Beekyman
    Beekyman Posts: 150
    edited April 2006
    I know its not in Sterling but my mother and I have entrusted all of our car repairs to the same mechanic for the past 20 years...ask for Tony of Professional Auto Care in Woodbridge, VA. He provides quality and professionalism at a very reasonable price. I live in Front Royal, VA (over an hour away) and I still take my cars there to be serviced!
    2 Channel Rig
    Source 1 - Apple TV
    Source 2 - Parasound D3 Universal Player
    Source 3 - Parasound Tuner T3
    Pre-amp - Parasound HALO P3
    Amplifier - Parasound HALO A21
    Speakers - Martin Logan Vista
    Power Conditioning - Panamax M5100-EX
  • MrBuhl
    MrBuhl Posts: 2,419
    edited April 2006
    Hey - Thanks for the tips fellas!
    98 Mazda Protege with 105K on her. Fried clutch in the A/C Compressor banging struts are bottoming out. (A/C no longer produced in two piece - must buy whole compressor I have been told) and it does need struts all around admitedly.
    I am a fair shade tree mechanic (did brakes, shocks, full leaf sping suspension kit with lift and transfer drop on my Jeep by myself) so I think I could do the struts given the time - but they want $2200 for everything here and hell, the retail blue book isn't even that on the whole car!
    I know the A/c will be top dollar - I am just plain pissed to be told that $220 worth of struts (of course I checked) are going to cost me $1200 including parts to install. BULLS_ _ T! That's like the $600 brake job scam.
    OK - Rant is over now.
    Thanks for the help - keep em coming if anyone has experience with the struts or a reasonable mechanic.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • MrBuhl
    MrBuhl Posts: 2,419
    edited April 2006
    No - What time is he on? Will check out.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • dorokusai
    edited April 2006
    Goss' Garage with Pat Goss on WJFK
    NEW: For Live Streaming... http://1067freefm.com/pages/1851.php
    Every Weekend
    Saturday: 12 - 4 pm
    Sunday: 11 am - 3 pm
    http://www.goss-garage.com/
  • Polkersince85
    edited April 2006
    May want to check with your local parts store, Auto Zone, etc, they may have access to the Junkyard database. Swap it out, new O-rings, pull a vac., put $12 worth of R134a and you are good to go.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited April 2006
    Hmmmm... you may be on to something here. Hadn't thought about used parts, thanks!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
