Parts Express question......
brettw22
I'm going to be building a sub box for my car, but I need to know if any of you guys that buy parts like this often are familiar with something a bit better.
THIS is what I'm looking to get, but I've seen some of the better individual binding posts, but none that look like they're a part of the plates or even could be integrated into the plates.
I'm putting 2 subs in the box, thus the preference for a plate with 2 pair together rather than individual plates for each pair. Also, I like the recessed area rather than a flush surface mount where the posts aren't inset.
Brett,
You might try the Vampires, BPHEX, I think. They are fairly compact if you take them off the little block they come with.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Do you have a link by chance that I can check out?comment comment comment comment. bitchy.
Here ya go:
Vampire BPHEX
I've bought them from Welbourne Labs a ona couple of occasions. Quick shippers and no problems.
You can also buy them direct from Vampire Wire. Either one would work.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Except neither of those options gives me a plate that's recessed and capable of holding both pair of the binding posts.comment comment comment comment. bitchy.
Can you sink a counter bore into the wood? Or, use a router? If I'k all wet, show us a sketch to better illustrate your situation.Carl
Click on the link in my first post. THAT's what I'm looking for, but wanting something with upgraded posts and not el cheapo's.comment comment comment comment. bitchy.
Why not use the PE plates and upgrade the posts?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Brett, will you be running the subs in parallel? If so, you just need one set of posts and you can combine the wire on the inside.
Each sub will have it's own amp, so the wiring is going to be from each amp to each sub (by way of it's own binding posts).
I suppose I could just upgrade the posts like that.......jues tseems like there should be a plate with upgraded posts.....comment comment comment comment. bitchy. -
How about these?
http://cgi.ebay.ca/Dual-terminal-gold-plated-input-cup_W0QQitemZ5790872246QQcategoryZ79840QQcmdZViewItem
They're not vampire but the binding posts are a step up. I've purchased from them before. Good experience.
regards
DaveTime is the best teacher. Unfortunately it kills all its students. -
They look cool...you can order stock LSi binders from Polk as an option as well.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
dorokusai wrote:Why not use the PE plates and upgrade the posts?
Yeah, I thought that's what you had in mind in the first place, Brett.
It didn't actually cross my mind to swap them out.........sad....
I put a call into Polk for the price on the LSi binding post.....I think that might be my best option from a QC standpoint.comment comment comment comment. bitchy. -
Polk CS only sells the binding posts with the crossover connected, so that would be a $50 route, but with what places like parts express or a few other higher end posts would end up costing, $50 doesn't sound bad for the plate, and all 4 posts.comment comment comment comment. bitchy.
If you want an LSi plate with binding posts I'll throw one in the mail for you.
Brettw22 i have a pair of the parts express plates if you want them. you can have them free.they are missing the jumper bars though. pm me and i will mail them to you.
bob -
Are they a pair of sing pair posts or a pair of dual pair posts on the plates?
I only really need a total of 2 pairs of posts.......... if they're split up that's not a problem .
PM sent.....comment comment comment comment. bitchy.
