Need a new USB flash drive. Any suggestions?
Mike682
My Sandisk cruzer micro decided to corrupt my files and as a result, my files on the drive were lost. Most of them were backed-up elsewhere and retrieved. I did get lazy and didn't back up the newer files during the past two weeks so I lost these files for good. It seems the drive can no longer permanently save files.
Anyway, I would like to get some opinions on others' experience with USB drives and any brands that work well.
I've been looking at, but not limited to, Crucial drives because they have a lifetime warranty. I would also consider a Sandisk again even though they only have a two year warranty....I guess I just need some re-affirmation of the Sandisk name.
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Mains: polk R30
Center: polk CSi3
My dad has been using a USB flash drive from SanDisk for about a year or so now. He hasn't had any problems with it.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
I use the heck out of my sandisk. I had a 256, just got a 1m.
I always take time to shut it down before yanking(often im grabbing logs off a server-don't need any glitches there!).
I like the thin size, and the green light to tell me if its active is essential!
If its still active, I need to know or there will be hell to pay if i pull it live.
$29 was the right price , too."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Get the Cruzer Titanium........never have to worry about a cap (the USB is retractable), completely metal encased and is rated to be able to withstand 2000 pounds.
I have 2 1GB's and GLADLY got rid of the micro because of their **** plastic caps.comment comment comment comment. bitchy. -
I have a little 256MB Sony that works well. It has the ability to partition the drive and secure one part. You can set each side of the partition however large you want. I'm sure I paid a little extra for the Sony name, but I thought some extra security on the drive was worth it.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
This is one where they rate a few
http://www.tomshardware.com/2005/05/20/data_transfer_on_the_run/
also go to fatwallet.com and they have tons of deals on their forums....
such as this one which i tried...but will expire soon
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=a0453407
No rebates...Ok so this deal is not so hot but If someone's looking for a 4gigger w/o rebates this might help.
At Checkout apply $20 off $150 or more Coupon Code : BLKSK2?5HVT$D0 (Exp 04/20 6am CST or 1000 uses)
Final Price: $161.95 - 20% instant - $20 = $109.56 + Free Shipping + No Tax in most states
so anyway there are tons more on there.
Hope that helps.
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
That's a great price for that drive schris......but my experience with that particular model with the cap is that it's a pain in the ****. The one good thing about that model though is that there's no additional size to it so it won't affect plugging in another USB device into the drive next to it where some of them with flared bodies will make you unable to use another slot if your machine has a few next to each other.
THIS is a HELL of a deal on this thing.......I'm almost thinking about getting it myself.comment comment comment comment. bitchy. -
i work with the one i gave the link to, everyday. It's not the best...i'll admit, they get bent and are slow...so the titanium version might be better if thats what you need.Receiver: Onkyo TX-SR502-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Thanks for the info guys, and thanks for the links Schris22 and Bretw22.
Stores have some damn good prices on these drives today.Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
DVD: Panasonic DVD-S29 -
audiobliss wrote:My dad has been using a USB flash drive from SanDisk for about a year or so now. He hasn't had any problems with it.
I had mine for about a year and a half before it died. Can't find the receipt to prove this to Sandisk.
I heard that when these things die, they die fast with very little warning. Make sure he has his files backed-up just in case..Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Their are so many of these drives available now, the choices are limitless.. I would test drive a few and see, I assume they are returnable.. or go with a suggested model that has been used and known to be goodMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
My rule on USB drives is only buy ones that are only SLIGHTLY wider than the plugin in, especially if you use laptops. otherwise you may end up unplugging other cables to get it to fit.
No USB is protected from corruption problems, etc. I'm on my third one in five years. I do try to reformat it every few months.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
It is true that whatever you have loaded onto it you should have a copy of somewhere else..........it just takes once for it to corrupt and kill everything on it.comment comment comment comment. bitchy.
I've been using a small 32MB Kingston for about 3 years now (it was on closeout for about $15 back then). No corruption problems. I've never bothered to reformat it either. I mainly use it to take files from work to home and vice versa. 32MB sounds small, but I mainly deal with Word/Excel files that aren't very big to start with. Sometimes a PDF or two and a handfull of photos, but I've never filled it up all the way. I'll probalby pick up a larger one at some point, but thus far, I haven't needed it.
I've been using a Kingston 1GB for about a year now. By accident I ran it through the washing machine for about 10 minutes last summer. Reformatted it, and have used it at work almost every day since. Lost the cap long ago though.
I have a PNY Attache 512 MB USB Drive, it's been on my keychain for about a year now. The outside looks a little scratchy, but the cap stays on and I've never had a problem with it. Worky Good!
I have 2 SanDisk Cruiser Micros and both work great. One of them went through a complete wash cycle with the washing machine (opps). I dried it off the best I could and it worked fine (and still works fine).
If you want a fast thumb drive (even USB 2.0 labeled thumb drives usually take forever to copy data to and from), you need to be looking for a thumb drive with dual channels. Check out this OCZ thumb drive. This will be my next one :cool: -
Kris, that OCZ drive totally rules, that's my next one as well. Thanks for the tip.
I like the speed and size of the OCM, but those loseable caps bug the hell out of me.comment comment comment comment. bitchy.
I don't think that can really be avoided. My SanDisk thumb drives came with 2 different caps (1 that just goes over the plug and 1 that covers the entire drive). Both become loose after a very few uses and can be easily lost. The same with my Gateway thumb drive.brettw22 wrote:I like the speed and size of the OCM, but those loseable caps bug the hell out of me.
Honestly, I haven't seen a thumb drive that has a cap that won't come off (though some seem to last longer than others).
Still, that OCZ thumb drive is cheap and comes with a lifetime warranty. Plus, I haven't seen any other brands that include dual channel technology yet. -
I guess the only question I have is if the dual channel technology is propriatery and will it be showing up on other brands drives.......comment comment comment comment. bitchy.
Honestly, I don't know if it's more of a standard or if it's propritery and others will duplicate it.brettw22 wrote:I guess the only question I have is if the dual channel technology is propriatery and will it be showing up on other brands drives.......
I just noticed Crucial has one with dual-channel but from the specs, it doesn't seem to be as fast as OCZ's and it looks more expensive. -
If Sandisk starts implementing it on their titanium drive, that would be the ideal for me. The appeal of never having lid issues because of the retractable port is HUGE. With my SD Micro, I've had to bend/pry the drive back into shape on several occasions and I'm sure it's gonna die soon because of that.comment comment comment comment. bitchy.
I just got the SD 512 Micro for $19 from Radio Shack with rebates. Too cheap to pass up at this price. I don't use it for anything other than MS Office files, so no real speed issues here.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Ya, I can't really say that I've had any complaints with the drives that I've used.....just the overall design longevity issues with the port itself.comment comment comment comment. bitchy.
