Sound Dampening
Sure it will. Its worked so far. The difference was staggering when I slapped some Dynamat on the panels. Ive only got a couple trouble spots left.polkaudio sound quality competitor since 2005
on the door panels or the metal?
...and I just sat here on a Sunday afternoon read this whole thread...and I don't remember when it was posted...
I must be trying really hard to avoid doing my homework!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Mat material on metal of door and foam on door panel is the way to go.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
exactly1996blackmax wrote:Mat material on metal of door and foam on door panel is the way to go.
ok i have a question about sound dampening im going to be running two audiobahn 12 inch flame q 450w subs and two audiobahn 10 inch 450w subs the flame q's as well. i dont want my trunk to sound like a bag of aluminum cans, how do i prevent this.John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
Mucho mat material.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
they are powered by dodges old subs, hes helping me with box designs,too would rubber behind the tag help too, cause doesnt it vibrate alot also.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
I use Dynamat on the door panels and door skins and both for the same reason. Dynamat adds mass to whatever its stuck to which reduces the chances its going to vibrate and resonate.polkaudio sound quality competitor since 2005
Dynamat makes a trunk kit just like a door kit. Thats all you should need to get rid of the aluminum cans. Just make sure it's the Dynamat extreme and not the regular Dynamat.
allright good deal we all hate those aluminum cans dont we?John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
butyl mat is not just "mass loading." If you want that, stick to ashphalt mat like Brown BeadMacLeod wrote:I use Dynamat on the door panels and door skins and both for the same reason. Dynamat adds mass to whatever its stuck to which reduces the chances its going to vibrate and resonate.
