Center Speaker
rhulett
rhulett Posts: 89
Can anyone tell me if it is a problem to turn a center channel speaker upside down with the tweeter on the bottom. I have the CSI40 on top of a 55 inch projection TV tilted down, but the tone seemed to be off(seemed "flat"). I flopped it upside down and it did seem to open up the sound a bit. I have rti70's in the front and fxi30 in the rear.
Post edited by rhulett on
  • phuz
    phuz Posts: 2,372
    edited September 2002
    If it sounds good to you, run with it! (unless somehow this has a negative effect on the crossover or magnetic shielding - which I doubt)
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Agreed, hell, stand it on end if thats what blows your skirt up....
    Cheers,
    Rooster
  • ralph76
    ralph76 Posts: 36
    Cheers,
    Rooster
    Very funny Russman..... :lol:
    Polk RT600i's
    Polk C245i Center
    Jbl surrounds (need to find F/X300s) info anyone???
    Harmon Kardon AVR80
    Sony Processor SDP-E800
    Toshiba DVD SD-1200
    Sony Minidisk MDS-JE320
    Monster 400MKII Interconnects
    --all protected by PANAMAX 1000+
  • danger boy
    danger boy Posts: 15,722
    there was a guy on here earlier this year.. who claimed his speakers were suppose to be placed upside down. several people on here had words for him. but i guess there really is not harm in turning them over. but really, what will you gain by it? i wouldn't suggest doing that with any kind of tower speaker.. they would be to unstable upside down.
    PolkFest 2012, who's going>?
  • ralph76
    ralph76 Posts: 36
    danger boy,
    he is referring to his center channel speaker. :rolleyes:
    Polk RT600i's
    Polk C245i Center
    Harmon Kardon AVR80
    Toshiba DVD SD-1200
  • danger boy
    oops! my bad. i did turn my cs400i on it's side and tired it out as a left front. didnt' sound real good.
  • TroyD
    TroyD Posts: 13,124
    the dude insisted that if you turned the CS400i on it's end it sounded better. I tried it for grins and didn't notice that it sounded any different but it sure looked silly.
    BDT
  • capitan100
    capitan100 Posts: 172
    edited October 2002
    Have you tried to bi-wire it? I have a cs400, and when I bi-wired it, it seemed to open up a lot. sounds pretty darn good when wired normally too, but opened up and sounds great now... good luck.
    Sony DA7ES 7.1 A/V Receiver
    Sony DVP-NC80V - SACD/DVD player
    CS400 - Center channel
    RT2000i - Fronts
    RT1000i - Surrounds
    a/d/s MS3/u - subwoofer
    Hitachi 62 inch HD TV
    2 Channel Room
    Niles HDL-4 Speaker Selector
    Niles HDL-6 Speaker Selector
    Sony V555ES receiver
    Sony DVP-S7700
    Polk SDA-2B
    Polk Monitor 5
    Thiel 03a
    B&W 2001 ZMF
    Signet SL-250 B/U
    a/d/s L400e
    Wharfedale Valdus 100SE
    Polk PSW 350 - subwoofer
    Pioneer Elite Big Screen
  • capitan100
    edited October 2002
    also, does your receiver have eq controls for the speakers? I have a ton of equalizer adjustments on my receiver for every speaker. I like to fiddle with it to get the best possible sound. You may also want to fiddle with that as well.
    RT2000i - Fronts
    RT1000i - Surrounds
    2 Channel Room
    Sony DVP-S7700
    Polk SDA-2B
    Polk Monitor 5
    Thiel 03a
    B&W 2001 ZMF
    Signet SL-250 B/U
    a/d/s L400e
  • jdavy
    jdavy Posts: 380
    edited November 2002
    It might be you listening position. Do you have a tall tv and are you looking up to it? The 2-3" drop in the tweeters might be adjusting the vocal position for you ears. Hey if it works for you go for it.
  • Tom323
    Tom323 Posts: 2
    Since tweeters are highly directional, you want to be able to look right down them when you are in the sweet spot. thats the best way to position them.
    Running the speaker upside down wont hurt the speaker at all.
