Sound Dampening
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2006
    Sure it will. Its worked so far. The difference was staggering when I slapped some Dynamat on the panels. Ive only got a couple trouble spots left.
  • exalted512
    exalted512 Posts: 10,734
    edited April 2006
    on the door panels or the metal?
    -Cody
  • audiobliss
    audiobliss Posts: 12,518
    edited April 2006
    ...and I just sat here on a Sunday afternoon read this whole thread...and I don't remember when it was posted...
    I must be trying really hard to avoid doing my homework! :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited April 2006
    Mat material on metal of door and foam on door panel is the way to go.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • exalted512
    edited April 2006
    exactly
    -Cody
  • 98thumpin
    98thumpin Posts: 649
    edited April 2006
    ok i have a question about sound dampening im going to be running two audiobahn 12 inch flame q 450w subs and two audiobahn 10 inch 450w subs the flame q's as well. i dont want my trunk to sound like a bag of aluminum cans, how do i prevent this.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
  • 1996blackmax
    edited April 2006
    Mucho mat material.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • 98thumpin
    edited April 2006
    they are powered by dodges old subs, hes helping me with box designs,too would rubber behind the tag help too, cause doesnt it vibrate alot also.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • MacLeod
    edited April 2006
    I use Dynamat on the door panels and door skins and both for the same reason. Dynamat adds mass to whatever its stuck to which reduces the chances its going to vibrate and resonate.
  • cam5860
    cam5860 Posts: 632
    edited April 2006
    Dynamat makes a trunk kit just like a door kit. Thats all you should need to get rid of the aluminum cans. Just make sure it's the Dynamat extreme and not the regular Dynamat.
  • 98thumpin
    edited April 2006
    allright good deal we all hate those aluminum cans dont we?
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • exalted512
    edited April 2006
    butyl mat is not just "mass loading." If you want that, stick to ashphalt mat like Brown Bead
    -Cody
