Should I change speaker wire for MMC5250s?
kenstewart
Installing them today and I noticed the Polk wires for the speakers aren't very beefy ... not sure size, prob either 16 or 18 gauge ... should I change them for 12/14 gauge? Need to go out and check for sure but I have 12/14 gauge in the truck right now that will run from the amp to the crossovers.
Eclipse CD8445 HU
Image Dynamics CXS54 Chameleons component setup
Two 8" Image Dynamics ID8D2v.3 subs
MTX MXA6001 amp for subs
MTX MXA3002 2-channel amp for comps
Accumat and Peel-n-Seal
Stinger and Knukoncpetz wiring
Post edited by kenstewart on
They are 16 guage. No need to change the wires. The voltage loss in the difference between 14 to 16 guage wire over 6" is going to be so tiny that youll never notice it.polkaudio sound quality competitor since 2005
That's good news, thanks Mac. Back to the install
Eclipse CD8445 HU
Stinger and Knukoncpetz wiring -
Got 'em installed and they sound great!
Still need to fine tune, but so far with simple adjustments these sound very nice
Eclipse CD8445 HU
Just wait til they break in. Ive noticed with all the Polk speakers Ive owned that they tend to start out on the bright side. But after some use and tweaking they come along quite nicely.polkaudio sound quality competitor since 2005
Yeah I think I read that on here as well which is why I wasn't worried. It is a bit on the bright side right now, turned down the tweets to -3db which helped, so I hope they break in soon so I can make final adjustments to them.Eclipse CD8445 HU
Youll probably want to go all the way down to -6d b on that attenuator. I have mine bi-amped and the tweets gains are quite a bit lower than the mids.polkaudio sound quality competitor since 2005
Ok, will do, thanks. Same here (bi-amped) and the tweet gains are already a bit lower than the mids.Eclipse CD8445 HU
you dont need to change your speaker wire what you have will work fineJohn Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
98thumpin wrote:you dont need to change your speaker wire what you have will work fine
Thanks for that Captain Obvious. We already covered that.
