cap questions
iworkfortweeter
how many amps theoretically, could i power using one capacitor? i need three total amps running.
currently in car:
'00 Honda Accord LX V6
AEM V2 cold air induction
c400.4 amp powering a pair of momo 6500's
and a pair of momo 6x9's
alpine monoblock amp powering a jl w3 12''
custom fab work for tweeters
jl rca's, dist block and power/grounds
alpine cda 9857 head
three ground loop isolators
ipod integration, all songs at 320kbs
Post edited by iworkfortweeter on
theoretically, infinite amounts
how big are the amps? How big is your power wire? How big of a cap? How how how? If you work for tweeter, shouldn't you already be trained on this?
hehe j/k
BTW, caps are more for filtration of noise than for capacitance IMO. Sure they help a bit but a quality battery is the way to go.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
optima yellow top best battery there is.John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
i do home installs.currently in car:
ipod integration, all songs at 320kbs -
Forget about caps. They have their uses but a good battery and alternator should be the main priority and you can maybe throw a cap in there just to top things off. Still, unless youre competing in SPL, I dont think you ever need a cap anyway.polkaudio sound quality competitor since 2005
Some people use a cap as a bandaid with not so great results. The big three upgrade will give you more benefits than a cap.
http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=5;t=007801;p=Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
and if you ARE competing in SPL, caps hurt more than they help.Never kick a fresh **** on a hot day.
Toxis wrote:and if you ARE competing in SPL, caps hurt more than they help.
Huh?
Soembody needs to tell 98% of the SPL competitors out there that theyre doing it all wrong.polkaudio sound quality competitor since 2005
I thought so at first but when I did a walk through at USACi finals the past few years, I noticed less and less using them. So I went to a couple guys who work for RTTI and they broke it down to me. I was shocked but they said they don't actually deliver the power as fast as they need for instant bursts. But these are the big dogs, not the kids at most local shows. lolNever kick a fresh **** on a hot day.
98%? Your numbers are way off. Going to the get loud section of the usaci forum and ask how many competitors use caps. The answer is likely to be 0.MacLeod wrote:Huh?
I think that's the first time Cody has ever backed me up. hahaha Thanks!Never kick a fresh **** on a hot day.
Problaby because this is the first time that youve ever been right
Actually, i wouldnt say 0, but it would def. be slim to none...and if you discard all the people who havent been doing it for a while/really know what theyre doing, that number will decrease more
Actually we're probably all right.
You get into the Mod X and unlimited classes where guys have 20 batteries and alternators and there wouldnt be any need for a cap. But in the stock type classes youll see a bunch of them. Like the Stock class in USACi allows for only one batter and one alternator in the stock locations. Same for MECA's amateur and street classes.polkaudio sound quality competitor since 2005
well i just need to run three amps. two 975 watt four channels and one 400 watt two channel. or one, depending on my mood when i put it in. i am not competing in a comp. per se, just with myself. i want it to be **** LOUD. so tell me, how can i run three amps without sacrificing anything in my electrical?
also how to rid myself of annoying light/alternator hum...currently in car:
are you guys saying that alls i need to do is run all my power wires directly to the battery? maybe upgrade my alternator? won't that drain exessive power?currently in car:
Yeah. 2400 watts will drain a **** load of excessive power.
Run your amps off your battery and upgrade both the alternator AND battery if you have the means. That is a lot of juice to be supplying and I doubt that stock Honda alternator is up to it.polkaudio sound quality competitor since 2005
Toxis wrote:But these are the big dogs, not the kids at most local shows. lol
Hmmmmmm... nice back peddle. haha j/k broMacLeod wrote:But in the stock type classes youll see a bunch of them. Like the Stock class in USACi allows for only one batter and one alternator in the stock locations. Same for MECA's amateur and street classes.Never kick a fresh **** on a hot day.
basic stock in USACi is the only class in USACi that youll see a competitor with a cap...and that certainly doesnt count as 98% of the competitors:D
thanks for the real help. all politicians must leave my thread
currently in car:
most exellent quote, i might add...\M/:Dexalted512 wrote:theoretically, infinite amounts
-Codycurrently in car:
exalted512 wrote:basic stock in USACi is the only class in USACi that youll see a competitor with a cap...and that certainly doesnt count as 98% of the competitors:D
-Cody
Maybe you should actually go to a USACi show rather than listening to your boss tell you what theyre like, beeyotch!
The amateur, stock, street and such by far have the most competitors.polkaudio sound quality competitor since 2005
FYI, the 400.4 is NOT 975w.
I now see what kind of amps you're running (looked above and found your sig) and I'd say a 1 farad is MORE than enough for the 300.2. You really don't need a cap for the 4ch's unless you plan on pumping a lot of midbass (rather loud too) out of them, then I'd say a 1/2 farad to cover both will be sufficient. I'm sure you could get another 1 farad for the other two amps pretty cheap seeing you work in the industry so call it good. Why do you need dual 4ch amps? Never kick a fresh **** on a hot day.
100% true, still doesnt account for 98%.MacLeod wrote:Maybe you should actually go to a USACi show rather than listening to your boss tell you what theyre like, beeyotch!
Now truthfully, when you said 98% of competitors, did you mean people that know what theyre doing, or the person that comes in with his 4 pyle 15s in the trunk powered off his 5 gigawatt boss amp?
Oops, I missed that sig too. Yeah, those 400.4's will be less than 400 RMS each, and that 300.2 will be 500 so youve got 1300 RMS. Thats still a good bit.
Im with Toxis tho, dual 4 channels does seem a bit much. Why not just step down to a single 400.4 and 300.2 and your stock charging system should be plenty then.polkaudio sound quality competitor since 2005
MacLeod wrote:Oops, I missed that sig too. Yeah, those 400.4's will be less than 400 RMS each, and that 300.2 will be 500 so youve got 1300 RMS. Thats still a good bit.
and itll still be loud enough to burst eardrumsJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
simply because i can....nothing more than that..currently in car:
did you read my PM?Never kick a fresh **** on a hot day.
probably not you know how it goesJohn Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
don't trust no sales people anyhow...currently in car:
