cap questions
iworkfortweeter
iworkfortweeter Posts: 53
edited April 2006 in Car Audio & Electronics
how many amps theoretically, could i power using one capacitor? i need three total amps running.
currently in car:
'00 Honda Accord LX V6
AEM V2 cold air induction
c400.4 amp powering a pair of momo 6500's
and a pair of momo 6x9's
alpine monoblock amp powering a jl w3 12''
custom fab work for tweeters
jl rca's, dist block and power/grounds
alpine cda 9857 head
three ground loop isolators
ipod integration, all songs at 320kbs
Post edited by iworkfortweeter on
  • exalted512
    exalted512 Posts: 10,734
    edited April 2006
    theoretically, infinite amounts
    -Cody
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    how big are the amps? How big is your power wire? How big of a cap? How how how? If you work for tweeter, shouldn't you already be trained on this? ;) hehe j/k
    BTW, caps are more for filtration of noise than for capacitance IMO. Sure they help a bit but a quality battery is the way to go.
  • 98thumpin
    98thumpin Posts: 649
    edited April 2006
    optima yellow top best battery there is.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
  • iworkfortweeter
    edited April 2006
    i do home installs.
    currently in car:
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2006
    Forget about caps. They have their uses but a good battery and alternator should be the main priority and you can maybe throw a cap in there just to top things off. Still, unless youre competing in SPL, I dont think you ever need a cap anyway.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited April 2006
    Some people use a cap as a bandaid with not so great results. The big three upgrade will give you more benefits than a cap.
    http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=5;t=007801;p=
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    and if you ARE competing in SPL, caps hurt more than they help.
  • MacLeod
    edited April 2006
    Huh?
    Soembody needs to tell 98% of the SPL competitors out there that theyre doing it all wrong.
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    I thought so at first but when I did a walk through at USACi finals the past few years, I noticed less and less using them. So I went to a couple guys who work for RTTI and they broke it down to me. I was shocked but they said they don't actually deliver the power as fast as they need for instant bursts. But these are the big dogs, not the kids at most local shows. lol
  • exalted512
    edited April 2006
    MacLeod wrote:
    Huh?
    98%? Your numbers are way off. Going to the get loud section of the usaci forum and ask how many competitors use caps. The answer is likely to be 0.
    -Cody
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    I think that's the first time Cody has ever backed me up. hahaha Thanks!
  • exalted512
    edited April 2006
    Problaby because this is the first time that youve ever been right ;)
    Actually, i wouldnt say 0, but it would def. be slim to none...and if you discard all the people who havent been doing it for a while/really know what theyre doing, that number will decrease more
    -Cody
  • MacLeod
    edited April 2006
    Actually we're probably all right.
    You get into the Mod X and unlimited classes where guys have 20 batteries and alternators and there wouldnt be any need for a cap. But in the stock type classes youll see a bunch of them. Like the Stock class in USACi allows for only one batter and one alternator in the stock locations. Same for MECA's amateur and street classes.
  • iworkfortweeter
    edited April 2006
    well i just need to run three amps. two 975 watt four channels and one 400 watt two channel. or one, depending on my mood when i put it in. i am not competing in a comp. per se, just with myself. i want it to be **** LOUD. so tell me, how can i run three amps without sacrificing anything in my electrical?
    also how to rid myself of annoying light/alternator hum...
    currently in car:
  • iworkfortweeter
    edited April 2006
    are you guys saying that alls i need to do is run all my power wires directly to the battery? maybe upgrade my alternator? won't that drain exessive power?
    currently in car:
  • MacLeod
    edited April 2006
    Yeah. 2400 watts will drain a **** load of excessive power.
    Run your amps off your battery and upgrade both the alternator AND battery if you have the means. That is a lot of juice to be supplying and I doubt that stock Honda alternator is up to it.
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    Hmmmmmm... nice back peddle. haha j/k bro
  • MacLeod
    edited April 2006
    Id make a hell of a politician! :p
  • exalted512
    edited April 2006
    basic stock in USACi is the only class in USACi that youll see a competitor with a cap...and that certainly doesnt count as 98% of the competitors:D
    -Cody
  • iworkfortweeter
    edited April 2006
    thanks for the real help. all politicians must leave my thread ;)
    currently in car:
  • iworkfortweeter
    edited April 2006
    -Cody
    most exellent quote, i might add...\M/:D
    currently in car:
  • MacLeod
    edited April 2006
    -Cody
    Maybe you should actually go to a USACi show rather than listening to your boss tell you what theyre like, beeyotch! :p
    The amateur, stock, street and such by far have the most competitors.
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    FYI, the 400.4 is NOT 975w. ;) I now see what kind of amps you're running (looked above and found your sig) and I'd say a 1 farad is MORE than enough for the 300.2. You really don't need a cap for the 4ch's unless you plan on pumping a lot of midbass (rather loud too) out of them, then I'd say a 1/2 farad to cover both will be sufficient. I'm sure you could get another 1 farad for the other two amps pretty cheap seeing you work in the industry so call it good. Why do you need dual 4ch amps?
  • exalted512
    edited April 2006
    100% true, still doesnt account for 98%.
    Now truthfully, when you said 98% of competitors, did you mean people that know what theyre doing, or the person that comes in with his 4 pyle 15s in the trunk powered off his 5 gigawatt boss amp?
    -Cody
  • MacLeod
    edited April 2006
    Oops, I missed that sig too. Yeah, those 400.4's will be less than 400 RMS each, and that 300.2 will be 500 so youve got 1300 RMS. Thats still a good bit.
    Im with Toxis tho, dual 4 channels does seem a bit much. Why not just step down to a single 400.4 and 300.2 and your stock charging system should be plenty then.
  • 98thumpin
    edited April 2006
    and itll still be loud enough to burst eardrums
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • iworkfortweeter
    edited April 2006
    simply because i can....nothing more than that..
    currently in car:
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    did you read my PM?
  • 98thumpin
    edited April 2006
    probably not you know how it goes
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • iworkfortweeter
    edited April 2006
    don't trust no sales people anyhow...
    currently in car:
