Rti8 + PSW 505 or Rti 12 only
Tequila
Tequila Posts: 104
edited April 2006 in Speakers
Yes. That´s the question.
Rti 8 has great sound and with the power bass from the psw 505 is a great team.
But the Rti12 has 3 wooffer inside. But The Rti 8 is very high clear¡
I don´t know.
thank you for your reply.
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited April 2006
    i know i hate when people answer answer my question with an option i didnt ask about but here i am gonna do the same for you. Get the RTi8 and get an SVS subwoofer from SVSound.com. That will be your best option for the money.
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • Willow
    Willow Posts: 11,371
    edited April 2006
    Depends on what you are driving your mains with, if you are using a decent to very good receiver I say the rti8 with a sub. If you are using a seperate amp then I say the either the 8's with a sub or the 12's with a sub. There is no way the 12 will be able to provide what a powered sub can provide.
  • ronnie
    ronnie Posts: 150
    edited April 2006
    the 12's have decent bass when bi-amped, but my experience is you still need a quality sub(which i still need also). i think every good system needs a sub. a sub is really the only way to get the real low notes that are needed in music and ht
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Yamaha CD685 cd changer
    Yamaha Dvd c950 dvd changer
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    Polk RTi6 (surround and surround back)
    Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
    WindyWillys cooling fan (works great)
    Mitsubishi 52in big screen
    blue jeans cables
    AR interconnects
  • Joey_V
    Joey_V Posts: 8,606
    edited April 2006
    My take?
    Depends on what you want to do.
    If you want to go towards a multichannel HT setup - then go with the 8s and go with an SVS like Stopher suggested.
    However, if you want to go towards stereo 2 Channel listening - I wouldnt go with a sub. I'd go with the RTi12.
    However, take into account I'm only looking at bass integration here.
  • Tequila
    Tequila Posts: 104
    edited April 2006
    ok,ok,ok
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2006
    I agree with Joey V. If you are only looking to listen to 2 channel music, I usually turn my sub off and put towers to large so RTi12's would be best, or better yet LSi 15s : )
    But, if you watch movies regularly (or are really into rap music), you'll want the sub for the explosions and such, get the RTi8s and a HSU, SVS, or I like my Omni s-12 (musical and cheap at Tweeter if you can find one).
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • GATOR3000
    GATOR3000 Posts: 355
    edited April 2006
    Rti8’s + PSW505 sub. Not because I have them both, but because they sound good together if properly calibrated for HT.
    Rti12’s are very nice speakers and need a lot more juice than the Rti8’s to get the best out of them. External amp is a must.
    If you are planning to run the Rti8’s with an external amp later, they would really open up for you. Also, the 12’s are considerably bigger in size than the 8’s, something to consider.
    IMO the Rti series speakers are meant for HT application. LSi’s with a nice sub is the way to go for 2-channel music system, providing you want to stay with Polk speakers.
    Gator :):)
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
