Banana plugs and wire thickness.
gidrah
gidrah Posts: 3,050
Does anybody know of banana plugs that are capable of using thick wire? I'm thinking 10 awg or thicker. I'm also thinking about using the kind that can have another set plugged into the back and splitting the strands. Unfortunately this would make for additional connections and would double the expense. Especially if I bi-wire/amp.
Make it Funky! :)
Post edited by gidrah on
  • phuz
    phuz Posts: 2,372
    edited September 2002
    Yes.
  • gidrah
    gidrah Posts: 3,050
    Phew! That's good.
    Make it Funky! :)
  • phuz
    phuz Posts: 2,372
    Sorry, I misread your "of" as "if."
    I've seen it done, but I'm not sure what brand they were etc.
    Any pro-audio shop should have them though.
  • gidrah
    gidrah Posts: 3,050
    I just got done checking out Parts Express. They've got some that will handle 8 awg @ $7.00 for a set of 4. I guess I shoulda looked around.
    Make it Funky! :)
  • etrigan
    etrigan Posts: 160
    Radio Shack has some nice Dual ban. plugs that are also "stackable - wire thru the side,then screw down on it kinda connection. Other than that and a SPL meter,wouldn't advise you shop there ;)
    CHEERS ! jefff
    Art as expression-Not as market campaigns-Will still capture our imaginations.
  • gidrah
    gidrah Posts: 3,050
    They do carry some other decent stuff. I'll probably check out their plugs, but I doubt they'll take 8awg.
    Make it Funky! :)
