Beginners Question?
jlf8686
I'm currently remodeling my home. I have a unique Mid Century Modern home that is very open/vaulted. I have a set of the Polk Audio 6800 series. I was curious if any of you could recomend the best location for my sub. I would like to put it in a small walk in closet that is adjacent to the living room where the system will be used. From what I've read this is a bad idea, Just curious if there were any locations that I could hide the sub so that it is not setting out in the open. I want to thank you all in advance.
If you want a visual of the house I'm talking about go to www.drummondhome.blogspot.com
Jerad
Jerad
Post edited by jlf8686 on
Go to a Bose showroom and ask one of those guys what to do - whatever they say, do the oppsite.
Sorry - couldn't resist!
Don't put the sub in a closset. These links should help you:
http://www.polkaudio.com/education/advice.php
http://www.rotel.com/support/build-home-theater.htmDistant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes) -
I would put my sub out in the room and proudly display it. So if you cant do that call Polk they have a great in wall sub which is ideal for remodels or new construction.
RT1 -
Since you are in the midst of remodeling, and are looking for stealth installation, I would look to the in walls/in floors. I have heard them personally, and they do a very good job.
Info on the Polk offerings can be found on this site, or you could go the DIY route.
If you want to use the closet, you could use it for an infinite baffle set up. That would probably be overkill for your purposes. -
Depending on the size of the sub and the TV set-up, it may be possible to put it behind the TV as well.
What kind of sub is it your looking to hide?The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
jlf8686 wrote:
Not to change the topic, but dude... that house you are redoing is in OP, KS isn't it? I am in the house flipping business as well, and I saw this house when it was on the market in January! this is just crazy.. I was like, cool he's fixing this place up.. and then I looked closer, and wouldn't you believe it, it is the same one!
Keep me posted! This is exciting to get to see the house renovated. I love the changes that will take place in such a house!
You gonna live in it, or flip it?
DavidHonoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
reeltrouble1 wrote:I would put my sub out in the room and proudly display it. So if you cant do that call Polk they have a great in wall sub which is ideal for remodels or new construction.
RT1
Have you heard the in-wall sub? Looks interesting to me. Any idea of how it performs compared to others at its pricepoint? (of course, they can charge more for the added value of being built into the wall.)HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
Mr. Nightly, thanks for the interest in my project. I plan on living in it, its just to expensive of a project to flip immediately. Everyone else thanks alot for you suggestions, I've looked into all of the solutions you've mentioned.
I think from a budget standpoint I'm going to have to live with the sub I have and deal with being able to see it from the living room
Jerad Foster
