Beginners Question?
jlf8686
jlf8686 Posts: 2
I'm currently remodeling my home. I have a unique Mid Century Modern home that is very open/vaulted. I have a set of the Polk Audio 6800 series. I was curious if any of you could recomend the best location for my sub. I would like to put it in a small walk in closet that is adjacent to the living room where the system will be used. From what I've read this is a bad idea, Just curious if there were any locations that I could hide the sub so that it is not setting out in the open. I want to thank you all in advance.
If you want a visual of the house I'm talking about go to www.drummondhome.blogspot.com
Jerad
Post edited by jlf8686 on
  • crazy
    crazy Posts: 443
    edited April 2006
    Go to a Bose showroom and ask one of those guys what to do - whatever they say, do the oppsite.
    Sorry - couldn't resist!
    Don't put the sub in a closset. These links should help you:
    http://www.polkaudio.com/education/advice.php
    http://www.rotel.com/support/build-home-theater.htm
    Distant Dream - A New Beginning
    www.distantdream.com
    (Now also available on iTunes)
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2006
    I would put my sub out in the room and proudly display it. So if you cant do that call Polk they have a great in wall sub which is ideal for remodels or new construction.
    RT1
  • amulford
    amulford Posts: 5,020
    edited April 2006
    Since you are in the midst of remodeling, and are looking for stealth installation, I would look to the in walls/in floors. I have heard them personally, and they do a very good job.
    Info on the Polk offerings can be found on this site, or you could go the DIY route.
    If you want to use the closet, you could use it for an infinite baffle set up. That would probably be overkill for your purposes.
  • Zen Dragon
    Zen Dragon Posts: 501
    edited April 2006
    Depending on the size of the sub and the TV set-up, it may be possible to put it behind the TV as well.
    What kind of sub is it your looking to hide?
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
  • MrNightly
    MrNightly Posts: 3,370
    edited April 2006
    Jerad
    Not to change the topic, but dude... that house you are redoing is in OP, KS isn't it? I am in the house flipping business as well, and I saw this house when it was on the market in January! this is just crazy.. I was like, cool he's fixing this place up.. and then I looked closer, and wouldn't you believe it, it is the same one!
    Keep me posted! This is exciting to get to see the house renovated. I love the changes that will take place in such a house!
    You gonna live in it, or flip it?
    David
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • Lowell_M
    Lowell_M Posts: 1,660
    edited April 2006
    RT1
    Have you heard the in-wall sub? Looks interesting to me. Any idea of how it performs compared to others at its pricepoint? (of course, they can charge more for the added value of being built into the wall.)
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • jlf8686
    jlf8686 Posts: 2
    edited April 2006
    Mr. Nightly, thanks for the interest in my project. I plan on living in it, its just to expensive of a project to flip immediately. Everyone else thanks alot for you suggestions, I've looked into all of the solutions you've mentioned.
    I think from a budget standpoint I'm going to have to live with the sub I have and deal with being able to see it from the living room
    Jerad Foster
