Receiver for RM6800
pare
pare Posts: 11
edited October 2006 in Basic Hookup/Wiring Questions
Hi. I made my first polk purchase today. I just placed an order for RM6800 speaker system. I have not yet decide on the receiver for drive these.
I mostly listen to music and rarely watch movies. I have a budget contraint because I stretched on the speakers. Please recommend a reciever for 250-300$.
Thanks in advance for your time and advice.
Post edited by pare on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2006
    http://www.onecall.com/ProductSearch.aspx?sHist=12-125&Sort=lowPrice
    The Pioneer 815 and 1015 are very nice in this range, as are the Harman Kardon, an Onkyo models
  • pare
    pare Posts: 11
    edited March 2006
    thanks for your quick response.
    I found a Harman Kardon AVR 240 7.1 in my price range
    Front power per channel (surround mode): 50 watts
    Rear power per channel: 50 watts, THD: 0.07%
    The only question is would have enough power (50W x 7) to drive the polk speakers?
  • Dennis Gardner
    edited March 2006
    HK power is real power. Equal to others that claim 100wpc. Don't worry, the 240 will drive the 6800 to their limits.
    I use an HK receiver for my home theater and love it. AVR7200
  • plattq45
    plattq45 Posts: 50
    edited March 2006
    Onkyo Tx-sr503, very nice and good price.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited March 2006
    I would question why you chose a home theatre system then? You could have done MUCH better for music listening, and for less money.
  • pare
    pare Posts: 11
    edited March 2006
    I wanted something good once for all and so I picked up polk HT speaker system.
    I would not want to spend time and money on HT for a long time to come.
    I appreciate all the help and I like this forum.
  • vipari
    vipari Posts: 10
    edited April 2006
    Pioneer 1015 rox
  • cstpeter
    cstpeter Posts: 387
    edited April 2006
    I second the HK. I had an entry-level AVR130 rated at 45w, and it drove my Sapphire ST1 floorstanders just fine. And that blue volume control is pretty sweet looking.
    Von Schweikert VR4-jr
    Valve Audio Predator
    Denon DVD-2900
    PS Audio Digital Link III w/Cullen Level IV Mods
    Pro-Ject Xpression w/Blue Point No. 2
    Graham Slee Special Edition 2
    PS Audio UPC-200
  • pare
    pare Posts: 11
    edited July 2006
    Hi. Time has come for me to upgrade and add a new HDTV to my home theater. Now the problem is hooking up the avr340 to the hdtv. its does not have a HDMI/DVI output and so does it mean that I have to live with my current tv or buy a higher end receiver. I am yet to buy a hdtv but I will most probably be buying 32" LCD TV from either sony, samsung or panasonic.
    I know this question I should be asking harmon kardon but I guess there are lot of people here who can point me in the right direction. thanks for your time.
  • brijenjas
    brijenjas Posts: 311
    edited July 2006
    You do not have to run your video through your AVR, although it is more convienent for most people.
    I am a firm believer having the least amount of connections between the source and the television; less connections, less chance to introduce noise.
    I recently purchased the HK AVR 340, but the only video I have coonected is the video out from the receiver to the TV for the OSD.
    My DVD player is HDMI(using video portion only) straight to tv, cable is straight to the tv. My television is Sony KDF-E42A10 HDTV.
    The AVR 340 does have 2 component inputs. Most HD cable boxes nowadays have both DVI and component video out, and digital and analog sound out, so you could use the component connections for HD if you wanted to go through the receiver.
  • pare
    pare Posts: 11
    edited July 2006
    Thank you.
    Somebody told me that my receiver would be useless with hdtv and so I was a little concerned because its just 4 months old now. I also found this link while browing throught that suggests that avr340 has problems. I didnt understand much about the problem though.
    http://www.avsforum.com/avs-vb/printthread.php?t=627898&page=4&pp=60
    But if the receiver is not used atall for the video, we should not have any problem.
  • atoyot1031
    atoyot1031 Posts: 1
    edited October 2006
    I also just purchased a rm6800 system. Is anyone running this with the SR504? I'm wondering if that will have enough power and inputs. I'll need to hook up:
    42" LG LCD
    HD DISH network dual receiver
    Nintendo GameCube
    DVD/CD player
    ipod
    My old system is ancient, so I didn't have to deal with component inputs, and only my DVD player was S-Video. I would like to welcome myself to the 21st century! Any input would be great. I need to buy my receiver from Circuit City (financing) and this was the receiver that seemed like it would match up nicely and is priced nice as well ($269). But if I have to spend another $100 to get it right, no big deal. By the way, we don't watch movies or listen to music too loud, so I'm worried about cranking it.
    Thanks for any input!
    Nick
