What will I need?
T-Bone
Post edited by T-Bone on
you might want to consider a cable outlet, but you probably won't need that now in the day of digital boxes...
at least make sure you have enough room to run all your wires from the various sources back there... -
You might want to put in a big outlet box with conduit running to where ever you're going to put the receiver or AV rack.
At the very least I'd run a 1" conduit to a double gang box from where you plan to put your AV rack to where you plan to hang the TV
Edit: Steve is right. Pick a place for the AV rack and put in a pad. Or at least a couple of boxes... -
Definitely have a "pad" with all of your audio/video connections run to where the system will be, you'll be glad you did.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
nothing more than an outlet. make sure to have it installed.currently in car:
'00 Honda Accord LX V6
AEM V2 cold air induction
c400.4 amp powering a pair of momo 6500's
and a pair of momo 6x9's
alpine monoblock amp powering a jl w3 12''
custom fab work for tweeters
jl rca's, dist block and power/grounds
alpine cda 9857 head
three ground loop isolators
ipod integration, all songs at 320kbs -
Wrong again.iworkfortweeter wrote:nothing more than an outlet. make sure to have it installed.
You really need to re-evaluate your career choice. -
Don't forget some construction in the right place for mounting the plasma
???1BigNovice wrote:Don't forget some construction in the right place for mounting the plasma
steveinaz wrote:Definitely have a "pad" with all of your audio/video connections run to where the system will be, you'll be glad you did.
+1, better to have it and not need/use it than to,,, (you know the rest of the story)
