LSi25s (front) Phase setting (Norm vs. Rev)?
aat
aat Posts: 45
Hi experts,
I use my LSi25s as the front speakers and what should I set the Phase setting to (Norm or Rev)?
Thanks,
AAT
Post edited by aat on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2006
    You should set it to whichever way sounds better, dont worry if you dont hear any difference between the two settings.
    RT1
  • unc2701
    unc2701 Posts: 3,587
    edited April 2006
    I would recommend playing an 80hz test tone while having someone flip the phase switches (typically they're gonna need to be in the same position). You're listening for it to be a little louder in one position. as RT says, it doesn't always make a difference.
    Backburner:Krell KAV-300i
  • Eric W
    Eric W Posts: 556
    edited April 2006
    In the various rooms I've tried the LSi25's generally I've found normal to be a better setting. However, from time to time in certain rooms the rev setting sounds better. No matter which setting you choose, make sure both speakers have the same setting.
    The best way to test this is to play some music (or if you have a test CD, some 1/3 octave pink noise (don't use a pure sine wave) around 80 Hz) with a fairly repetitive, but varied bass note. From your primary listening position, focus in on the area of sound which is below the male human voice, the upper bass/lower midbass region. Whichever setting sounds louder, fuller, "faster" in that region is the correct setting. If you cannot hear the difference, then leave it to 'normal'.
    -Eric
    -Polk Audio
  • SuperDave
    SuperDave Posts: 168
    edited April 2006
    I've got mine set to normal and the bass kicks:eek:
    SuperDave
    Yamaha RX-V992 (ADCOM GFA-5500 in transit)
    Denon DVD-1920
    Sony XBR 27"
    BrightHouse DVR
    Polk LSi25 Fronts
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
