Best music ripping and conversion software
AsSiMiLaTeD
I'm looking for the best software available for ripping music from CDs and converting from one format to another. I'd like this all in one package, and need lots of file type support for the conversion piece.
Any thoughts?
Any thoughts?
dbPowerAmp has been my favorite for a long time.If you will it, dude, it is no dream.
Eac.
dbPowerAmp is the one I downloaded this morning...haven't had a chance to play with it...
I wasn't aware that EAC had built in conversion capability. is there a version out there that has this - it's not in the version I have. -
I use EAC with outboard LAME encoder. The perfect combination.
EAC W/Lame is the HQ standard - IF you use it to it's full potential and know what you are doing. There are a lot of options which may or may not be of use or interest to you.
I use a program that does just about everything and uses lame for encoding. Easy CD-DA extractor. Burns, converts (lots of file types to and fro), extracts etc// a little bit of tagging and even CDDB look. $25 I think it was??Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
bobman1235 wrote:dbPowerAmp has been my favorite for a long time.
I like IMTOO software, but I had to get DBpoweramp to rip some different stuff, was impressed with DB.
I now use both. -
EAC. It's not the friendliest, but it does a better job ripping than anything else out there.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Polkmaniac wrote:dbPowerAmp is the one I downloaded this morning...haven't had a chance to play with it...
It doesn't but it's by far the best most accurate ripping program out there, not to mention it's free. The name Exact Audio Copy is exactly what it does. Other rippers (to my knowledge) don't extract an exact dupilcate of the .WAV. If you want it done with the best possible results it's going to be a 2 step process. EAC and then what conversion program you want to use.
Personally I use EAC for everything and then for music I'm archiving I use Flac Front End to convert to Flac, I don't bother with Mp3's unless I'm putting on a portable.
It's up to you.......there are a lot of rip and burn programs out there that do a good job, but EAC will give you the best possible result everytime. Just make sure to configure it properly once you DL the program; it will make it run a lot better (faster).
Well, I'm now convinced to download EAC, if I can ever figure out which version I want! Will somebody help me configure it? I used to use it, but I never could understand all the settings...
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Yeah, EAC is very nice and I've been using it for a while...
However for this project I'm looking to rip new CDs into wma for the car radio, and convert all the CDs I've ripped using APE, FLAC and EAC into WMA - also for that same purpose.
If you're looking for the best quality, EAC is the way to go, but not what I'm looking for...
This DB program is actually working well for me - think I'm gonna stick with it...
Thanks for all the replies -
I'm not familiar with the program but, if it works reliably everytime, then it sounds like exactly what you need.
