Best music ripping and conversion software
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited April 2024 in Clubhouse Archives
I'm looking for the best software available for ripping music from CDs and converting from one format to another. I'd like this all in one package, and need lots of file type support for the conversion piece.
Any thoughts?
  • bobman1235
    bobman1235 Posts: 10,822
    edited March 2006
    dbPowerAmp has been my favorite for a long time.
  • Demiurge
    Demiurge Posts: 10,874
    edited March 2006
  • AsSiMiLaTeD
    edited March 2006
    dbPowerAmp is the one I downloaded this morning...haven't had a chance to play with it...
    I wasn't aware that EAC had built in conversion capability. is there a version out there that has this - it's not in the version I have.
  • polksda
    polksda Posts: 716
    edited March 2006
    I use EAC with outboard LAME encoder. The perfect combination.
  • phipiper10
    phipiper10 Posts: 961
    edited March 2006
    EAC W/Lame is the HQ standard - IF you use it to it's full potential and know what you are doing. There are a lot of options which may or may not be of use or interest to you.
    I use a program that does just about everything and uses lame for encoding. Easy CD-DA extractor. Burns, converts (lots of file types to and fro), extracts etc// a little bit of tagging and even CDDB look. $25 I think it was??
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • avelanchefan
    avelanchefan Posts: 2,401
    edited April 2006
    I like IMTOO software, but I had to get DBpoweramp to rip some different stuff, was impressed with DB.
    I now use both.
    Sean
    XboxLive--->avelanchefan
    PSN---->Floppa
    http://card.mygamercard.net/avelanchefan.png
  • unc2701
    unc2701 Posts: 3,587
    edited April 2006
    EAC. It's not the friendliest, but it does a better job ripping than anything else out there.
    Backburner:Krell KAV-300i
    heiney9 Posts: 25,435
    edited April 2006
    It doesn't but it's by far the best most accurate ripping program out there, not to mention it's free. The name Exact Audio Copy is exactly what it does. Other rippers (to my knowledge) don't extract an exact dupilcate of the .WAV. If you want it done with the best possible results it's going to be a 2 step process. EAC and then what conversion program you want to use.
    Personally I use EAC for everything and then for music I'm archiving I use Flac Front End to convert to Flac, I don't bother with Mp3's unless I'm putting on a portable.
    It's up to you.......there are a lot of rip and burn programs out there that do a good job, but EAC will give you the best possible result everytime. Just make sure to configure it properly once you DL the program; it will make it run a lot better (faster).
  • audiobliss
    audiobliss Posts: 12,518
    edited April 2006
    Well, I'm now convinced to download EAC, if I can ever figure out which version I want! Will somebody help me configure it? I used to use it, but I never could understand all the settings...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • AsSiMiLaTeD
    edited April 2006
    Yeah, EAC is very nice and I've been using it for a while...
    However for this project I'm looking to rip new CDs into wma for the car radio, and convert all the CDs I've ripped using APE, FLAC and EAC into WMA - also for that same purpose.
    If you're looking for the best quality, EAC is the way to go, but not what I'm looking for...
    This DB program is actually working well for me - think I'm gonna stick with it...
    Thanks for all the replies
    edited April 2006
    I'm not familiar with the program but, if it works reliably everytime, then it sounds like exactly what you need.
