Speaker wire...?
noimposse
noimposse Posts: 264
So I was looking to getting some decent quality speaker wire for my rti4's. Dont kill me....but right now I'm running some awful Magnavox-on-a-spool 18ish gauge wire that I had with my old sony speakers. I figure getting something better might clear up the sound a bit, but I am nowhere close enough to wealthy.
The closest thing to what I could afford and actually like are a pair of DAYTON SCP-10 with bananas for around $40 on parts express. I think that would be able what I plan on spending for the cables, I just dont know if the Daytons would be the best I could get in that price range, or if they are worth getting at all.
Suggestions or comments are appreciated. Thanks.
Ghetto Rig
Power: HK AVR245.
Screen: LG 24" 1080p.
Speaks: Rti4.
Source: PC. PS3. Xbox360.
Cables: BlueJeans. Monoprice.
Post edited by noimposse on
«13
  • polrbehr
    polrbehr Posts: 2,842
    edited March 2006
    If you're looking for speaker cables at a decent price, look no further than Monster. They offer a lot of choices in a lot of price ranges. Acoustic Research wouldn't be your worst choice either, as long as you stay away from lamp cord. Both can be fixed up with banana plugs or other pin-type
    connectors. They both offer fine stranded wire, which enables it to carry
    current more efficiently since there is more surface area. Either way, I would go with 16AWG minimum, even for a short (<25') run, and of course make sure the connections are tight all the way around. Bad connections = resistance / heat = poor sound quality. Good luck.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2006
    Home Depot carries 12-14 guage. It will do you up just fine.
    RT1
  • Lowell_M
    Lowell_M Posts: 1,660
    edited March 2006
    Monster Wire is a waste of money. I was looking for 12 ga., but Home Depot was out...Parts express had 100 ft of 12 ga. cheaper and it works just great.
    Does anybody have any quantitative data to show that any higher cost speaker wire provides any better performance than a 12 gauge lamp cord? I read an article about the subject somewhere, but can't remember where.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • danger boy
    danger boy Posts: 15,722
    edited March 2006
    lamp cord was made for lamps. not audio. enough said.
    PolkFest 2012, who's going>?
  • noimposse
    edited March 2006
    So doing it myself is the way to go? The Dayton cables are not recommended?
    Ghetto Rig
    Power: HK AVR245.
    Speaks: Rti4.
  • reeltrouble1
    edited March 2006
    I have no **** with Dayton but would recommend diy. Can you tell a little about your rig? I know you said RTi4 speakers (very good) what kind gear are you using.
    RT1
  • Lowell_M
    edited March 2006
    I found the link to what I read before....http://www.roger-russell.com/wire/wire.htm. This is the only article that I have found that offers scientific reasoning for type and gauge of speaker wire. I agree that interconnect quality is important, but can't justify spending extra cash on Monster wire (or more expensive) after reading this. The only other information I have found is marketing information directly from speaker wire manufacturers (which is meaningless)
    Other than sarcastic comments....What are your opinions? Is there any actual data or reasoning to support buying expensive speaker wire?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • reeltrouble1
    edited March 2006
  • shack
    shack Posts: 11,154
    edited March 2006
    What a tired old article.....
    Unless you've actually tried it.....oh nevermind....I really don't care...use whatever....
  • polrbehr
    edited March 2006
    Excellent link, a matt. Saved me the trouble of breaking out my ohmmeter and checking all of the wire I have! As a point of information, the Home Depot near my home doesn't seem to have 12ga. stranded wire, so I offered
    Monster or another type as a readily available alternative. That article was very informative, though. I've learned quite a lot in my short time checking out this forum.
  • noimposse
    edited March 2006
    Well as of now, the only notable component are the rti4's. Im using a Kenwood vr-705 as an avr, and the generic speakers cable. The system is really just starting out....the Kenwood is hopefully going to be replaced with a HK 240 by the end of the year. My next purchase is a sub(possibly the Mirage s8) followed by a center channel(Csi3).
    I figured new wire might give me a cleaner sound and hold me over until I can afford all of the other things. College is a ****...
    Ghetto Rig
    Power: HK AVR245.
    Speaks: Rti4.
  • Lowell_M
    edited March 2006
    noimposse,
    I am by no means an expert in HT equipment and seem to have started somewhat of an argument, but although the linked article is old, the laws of physics don't change. I would say find yourself some 14 or 12 ga. stranded speaker cable that you can afford (parts express has some decent choices in my opinion. The important part is making sure you have good, clean connections at the ends of the wire. Copper corrodes over time and the connections may need cleaned from time to time.
    In time, if you have the $$$ to buy more expensive wire, give it a shot and see what your ears think.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • reeltrouble1
    edited March 2006
    We have had more wire debates around here than I care to remember. Wire matters, you have a starter system, starter wire is fine, actually 14 guage is fine. Get used to how it sounds, change out when or if your ready.
    Everything in the chain matters, you have years and years to enjoy audio and learn.
    Have fun.
    RT1
  • noimposse
    edited March 2006
    Thanks guys, the opinions are really appreciated.
    Since being at school kind of hinders actually getting to a home depot(its about 40 minutes away, and transportation is lacking...), off the top of your head, do you know what it may cost a foot/yard?
    As for monster, Ive always found them to be a bit overpriced for what they are, and Im a newbie. Best Buy reps pimp that crap like the manager has a gun to their heads.
    Ghetto Rig
    Power: HK AVR245.
    Speaks: Rti4.
  • John K.
    John K. Posts: 822
    edited March 2006
    Noimposse, unless the runs to your speakers are more than about 20', that "awful Magnavox" wire(if it is in fact 18ga)is all you need and you can't get clearer sound with a different wire. If the ends of the wire are corroded they should be cleaned or trimmed off, otherwise the speaker wire has nothing to do with any dissatisfaction you may have. The speakers and listening room should be looked to.
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2006
    Don't know about Home Depot wire, but Radio Shack's 12awg OFC is .99 cents a foot.
  • adam2434
    adam2434 Posts: 995
    edited March 2006
    Wow, less than a penny a foot - I'm going to run out and buy a few hundred feet!
    Just kidding - I knew what ya meant. :D
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • steveinaz
    edited March 2006
    good eye!
  • McLoki
    McLoki Posts: 5,231
    edited March 2006
    You can get 12 guage from Blue Jeans cable for .39/foot. (just an FYI)
    Michael
  • McLoki
    McLoki Posts: 5,231
    edited March 2006
    Out of curiosity, what, in your opinion, affects the sound that we hear from our systems? It seems cables and amps dont matter, but speakers and the room do. Please dont take this as an attack, I just want to understand your perspective. If I had 2 very similar rooms and sets of speakers, what would keep them from sounding identical to each other? (to keep things simple we will say the source is a cd or dvd player playing a digital media with standard analog cables to the pre-amp.
    Source - wire - pre-amp - wire - amplifier - wire - speakers - room.
    If the last two items in that chain are funtionally the same - what would account for different sounds between systems (or do you contend that the sound in each room would be the same?)
    Thanks - just trying to understand you perception.
    Michael
  • markopolo
    markopolo Posts: 18
    edited March 2006
    I just switched out some realy crappy thin wire for some 12ga from Home Depot. Got it for 98 cents/meter. I noticed an improvement in sound (at least I like to THINK I did). As far as I'm concerned everything Monster is grossly overpriced. I'm not saying that Monster isnt good wire just that you can get equally good wire without the Monster branding for way cheaper. But ppl like to convice themselves that if they spend a lot then it MUST be better than everything else.
  • John K.
    John K. Posts: 822
    edited March 2006
    Michael, it isn't simply an opinion or perception(I try to avoid that whenever possible); although we read endlessly about the "sound" of players, amplifiers and even pieces of wire, most of that is BS(Before Science)and although music is art, audio is science. Well-designed equipment playing at precisely the same level(adjusted to within 0.1dB)isn't audibly distinguishable in properly controlled blind listening tests(the only condition in which we truly have to "trust" only our ears). When the nameplates and pricetags have disappeared, so have the differences in sound which were previously described in flowery terms by the same listeners for the same equipment before the test. This is well-established factual information, but despite this, subjective (mis)impressions have created an audio fantasy world where the participants continually reinforce each others' illusions.
    What does matter and deserves our special attention(and money)in audio is the source material(e.g. CDs and DVDs, not the devices to play them), the speakers and the listening room. It isn't realistic to assume that any of these three factors are the same for different source materials, speakers and locations, but if it was arranged to have exactly the same source material playing through exactly the same speakers in exactly the same room setup, then by definition there'd be no difference in sound. There can be no effect without a cause.
    F1nut Posts: 51,732
    edited March 2006
    Fortunately, your cause has no effect here. Although, I do find your attempts to convince people that gear and cables don't make a difference quite humorous.
  • McLoki
    McLoki Posts: 5,231
    edited March 2006
    Sorry I have to disagree with you here. It is your opinion and I could not disagree with it more.
    If you are ever in this part of the world, stop by for a few beers (or the drink of your choice) and we can try to prove each other wrong. Until then, you will have to enjoy your system and I will have to enjoy mine.
    For all the new people seeking opinions, when we both respond - I guess they will hear both sides and hopefully they will be willing to test\listen\decide for themselves.
    Michael
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2006
    JohnK is also a fan of Axiom Audio...shouldn't he only be a fan of Fisher Price?
  • W WALDECKER
    W WALDECKER Posts: 900
    edited March 2006
    I am writing this from the safe confines of my audio fantasy world.power amplifiers from various manufacturers obviously sound different and if you have a few to compare side by side if you cannot tell the difference you must have a tin ear. if you have wire from different lines offered by the same manufacturer side by side and listen to them the differences in sound can be night and day apart. how can you explain this phenomina ?in a high resolution audio system everything in the chain from the source to the loudspeaker and everything in between makes either positive or negative difference! thanks....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • phipiper10
    phipiper10 Posts: 961
    edited April 2006
    Make your own decisions but I went from some monster speaker wire about 10 years old - "XP" in a pinkish insulation i think it was to switching t some Audioquest wire.
    I'm not advocationg spending lots of money or or even Audioquest but there was a LARGE difference. Does it mean monster sucks or AQ is awesome I don't know but I do know there IS a difference.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • nellis8166
    nellis8166 Posts: 292
    edited April 2006
    If you want to spend a little coin and get great wire check out Kimber Cables. I run 8tc on my rig, It made a huge difference.
    RTi10
    CSi5
    RTi28
    SVS PB12-ISD2
    Denon 2106(pre/pro)
    Adcom 5503(200x3)
    Audioquest Diamondback ICS
    Kimber Kable 8tc biwire(mains and center)
    "Don't let your silly dreams fall in between the crack of the bed and the wall."
    -J. James
  • shack
    shack Posts: 11,154
    edited April 2006
    Waaaaaaaaaaaa...... Yep the gear doesn't matter.
  • shack
    shack Posts: 11,154
    edited April 2006
    Maybe Jesse is right.
