HT Horse power
deq15
Ok What is the best way out to setup the home theater - MINUS the speakers.
Parameters are as follows...
at least 80W Ch. 5 channels - CLEAN power at FULL output
manages to decode DD and DTS
manages 2 Ch. devices -(Tuner,TV,CD,2-Aux)
cost not to exceed $1000 - remember no speakers yet
$$ amounts are pertain to the Used gear market
do you go with a receiver that does it all or do you go with a 5 ch amp (powered sub NOT included) and a preamp/Digital Decoder?
What brands and models would you go with?
Post edited by deq15 on
I chose...
Carver 5 Ch amp - AV505
Carver Preamp/Tuner
Technics Digital Decoder
$800 total
FYI - I have SDA CRS+ in all 4 positions and what I call a CRS+ composite for a center/Sub -
Cost not a factor, separates are ALWAYS the way to go. Having said that, for 1000 bones, you could probably go the same route as RonP did. Use a receiver as a pre and add separate amps as you go, the front sounstage being the most important.
Another option, if I were thinking of a receiver, would be the Carver C1000A. I friend of mine just bought one on closeout for 1100 or so a couple months back. I've only messed with it a little but it is VERY cool.
BDTI plan for the future. - F1Nut
