My God, what have I done?!!?!
I just drilled 4 holes into each of my 5jr's. Lemme explain. The tweeters in the speakers were blown, and I had 2 speakers in my basement from a speaker box that I'm building for my car. So I drilled holes and screwed the other tweeters in place. I promise all of you that as soon as I come up w/ the $100, I'll buy the replacement SL1000's. :-D Surprisingly enough, the tweeters sound okay, although they do not have as wide of a soundstage. They haven't seemed to effect the sound of the subs either (they weren't a perfect fit, and left some space on either side). I'm pining for those SL1000's, though. *pine* *pine*
DooD
DooD
Ludicrous gibs!
Post edited by nadams on
Nothin like an OH **** line as a hook........ :-) cracked me up......comment comment comment comment. bitchy. -
Man I feel for ya brother...though I don't think I could ever be impatient enough to drill holes in my speakers.....I'd prolly just use the surrounds until the new tweets came in, but oh well that's just me.
are you sure??
"They haven't seemed to effect the sound of the subs either"
I would think that you "venting" a sealed speaker, the bass woudl drop of like a rock?Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Originally posted by hoosier21
are you sure??
The speakers are ported already, I was just commenting that reducing the backpressure on the speakers had no effect on them. These are 5jr's, which have a little port below the driver, whereas 5jr+ speakers have a passive radiator instead of the port. Is this what you are thinking of?
DooDLudicrous gibs! -
BTW- the structural integrity of the speakers were not effected by this. Once I get the new tweeters, the holes will not be noticible, nor will they effect performance. I made sure of that....
yes I was thinking of the 5jr+Dodd - Battery Preamp
nadams,
Have you considered getting some thearpy? At least a twelve step program. There comes a time when we all realize we have a
problem, and we need to seek help. Mine came when I brought
speakers instead of food. Put the power tools down and back away from the speakers. Get yourself some help. Please !JmasterJ Polk to the Death
