i was bored...
MxStYlEpOlKmAn
MxStYlEpOlKmAn Posts: 2,116
edited September 2002 in Speakers
8.1 setup
mains: Lsi 15
Center: lsi 9
back center: lsi 9
front surrounds: lsi 9
back surrounds: lsi 9
subwoofer: M&k mx-125
lol i got this idea from phase speakers, they have this bookshelf thats everything...except a subwoofer. and its sorda just like the lsi 9...the tweeter is in the middle... newayz i was really bored
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
  • HBombToo
    HBombToo Posts: 5,256
    How does it sound? Music, Movies..... come on some detail for us to consider.
    ***WAREMTAE***
  • MxStYlEpOlKmAn
    lol i dont no...i said i was bored....and i just thought of that...although im pretty sure u wont have ne problems with matching...LOL!
    I promised myself
    Damn you all! - ATC
  • MxStYlEpOlKmAn
    if you put in consideration...the lsi c and the lsi9 are very close to being identical. i mean technically the most difference is the label and how they set...all u gotta do is turn the lsi9 on its side and u got a center channel. i mean theres not that much of a difference... and i dont like dipole or bipole...because i like 4 channel stereo. and i think im gonna change that setup there
    centers : lsi 9
    front surrounds: lsi7
    mains: lsi15
    subwoofer: 2 m&k mx125
    Receiver: yamaha rxv1 with seperates rotel or adcoms going to all channels...im even border than i was yesterday...
    I promised myself
    Damn you all! - ATC
  • MxStYlEpOlKmAn
    LSI 9
    Enclosure Bass Reflex
    Video Shielded Yes
    Tweeter Ring Radiator
    Midrange size (inches) 5-1/4
    Woofer size (inches) 5-1/4
    Woofer Composition Aerated poly
    Woofer Surround ---
    Power Range N/A
    Sensitivity 88 dB
    Impedance (Ohms) 4
    Frequency Response 50-26k Hz
    Connector Type 5-way post
    Bi-amp Inputs Yes
    Height (inches) 15-1/2
    Width (inches) 8-5/8
    Depth (inches) 15-1/4
    Mounting Bracket Included ---
    Recommended Stand Height (inches) ---
    Parts Warranty 5 years
    Labor Warranty
    lsic
    Timbre Matching Adjustment ---
    Tweeter RIng Radiat
    Midrange size (inches) ---
    Power Range ---
    Sensitivity 88 dB
    Impedance (Ohms) 4
    Frequency Response 52-26k Hz
    Height (inches) 7
    Width (inches) 21 3/4
    Depth (inches) 9
    Labor Warranty
    well you dont have to worry about your center being musical or not...lol
    I promised myself
    Damn you all! - ATC
  • Steve@3dai
    Steve@3dai Posts: 983
    Don't put a 9 on your TV that's fer sure :) But yes, they are quite almost the identical speaker.
    The C is very musical.
    LSi 9/C/FX
    Arcam AVR-200
  • MxStYlEpOlKmAn
    i no it is...lol...as i said before, i was just bored and i thought of that
    I promised myself
    Damn you all! - ATC
  • brettw22
    brettw22 Posts: 7,621
    Is the only reason not to put a 9 on your tv for aesthetic reasons? I don't agree with putting in more money for something that's designated a Center by simply labeling it as such, especially if you can get the same speaker for less as a front..........right?
  • Wesmo
    Wesmo Posts: 74
    I'm not sure why he said not to put it on a TV.....The lsi9 is fully shielded, and I don't think it would look much different from the lsiC if you placed the 9 on it's side. If you had a 6.1 system, it would seem ideal to buy a set of 9's and use the spare as the rear center. Just my .02.
    Wes
  • Steve@3dai
    When I placed my 9 on my TV as a test, it warped it quite a bit. That was without anything playing. The 9s are shielded, but not as much as a true center channel that is designed to be placed on top of the TV.
    LSi 9/C/FX
    Arcam AVR-200
  • MxStYlEpOlKmAn
    lol...i cant believe this post got all this replies when i was bored...you can put the 9 under your tv, in your shelf, on top of your entertainment center, put a piece of wood under the 9 and on top of the tv...lol, i dont care...but i dont see the point of buying a center when u can buy a pair of bs. newayz...im a bookshelf dude...if i were to run an audio company, i'd sale bookshelfs, and only bookshelfs, and just sale stands if someone wanted a floorstander...i cant floorstanding speakers...lol, and the cs245i... is a good center and all, but it in all things, IS NOT VERY MUSICAL! thats my opinion..
    I promised myself
    Damn you all! - ATC
  • Wesmo
    Wesmo Posts: 74
    No the 245i sure isn't musical. I had one for a few months, and could never run any 5.1 music because it just sounded unnatural....esp since it had smaller drivers than the rest of my setup. The 400i, however, sounds pretty good with everything else, and since I got a pretty good deal on it, and CC didn't have any 35i's left (I got the last two for my rears), I just went with the 400i, and have been quite content with the beast.
    Wes
  • Wesmo
    Wesmo Posts: 74
    Wow, that's probably the worst run-on sentence I've ever written. I guess that's what painkillers will do to you. Don't worry, I have a prescription for them :0]
  • joe logston
    joe logston Posts: 882
    can you buy just one lsi-9, i read that they are a mirrored pair.
    oh" are you sill bored
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • Wesmo
    Wesmo Posts: 74
    Yeah they are...the tweeters are located offset in the cabinets rather than in the center like the other polks. It's supposed to give better imaging I think. This wouldn't a problem if you were using it on it's side as a center or rear center.
  • MxStYlEpOlKmAn
    8.1...thats two centers, buy a pair of lsi 9's one cente rinf ront and back...lol, buy a pair of lsi 9's for back surrounds, 7's for front and and 15's for main
    I promised myself
    Damn you all! - ATC
