2 channel amp for RTi6
Hello guyz, i've a beautiful HT system for my living room, watching mainly movies on it on which i'm very satisfied with! I am thinking of buying a pair of RTi6 together with a 2 ch amp for the other room, just to listen to music!! Any suggestion about kind of Amp to handle the job?
Ahmedmo
TV: Loweve 93102 -40' CRT
AV Amp: Yamaha RX-V4600
DVD player:SONY DVP-CX985V
Front:Lsi 15s
Center:LSic
Surround:Fxi3
Sub:PSW 505
Front:Lsi 15s
Center:LSic
Surround:Fxi3
Sub:PSW 505
perhaps a parasound a23? You can find one used between $425-$550.2 Channel
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation -
Ahmedmo,
What is your price range and are you opposed to buying used?Proud SOPA Member since 2005! -
Hi Nebborjk,
Used would be OK for me ... and my price range would be MAX $500.. in fact i've a very good deal as well to get a pair of RTi10s instead of the RTi6!! In this case i need some Power i beleive..Ahmedmo
Front:Lsi 15s
Center:LSic
Surround:Fxi3
Sub:PSW 505 -
For music, stick with the RTi6 unless you wanna spend a lot more money to get those 10's to sound their best.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Heres a nice Parasound A23 on audiogon. asking $500
http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&11472327432 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
