LSi9 or LSiFX for rear surrounds?
They cost about the same. I was leaning toward the LSi9's. They will be wall mounted, both have plate in back for easy mounting. Any opinion would be appreciated. Thanks! Yes, I'm looking at amps too.
SuperDave
Yamaha RX-V992
Denon DVD-1920
Sony XBR 27"
BrightHouse DVR
Polk LSi25 Fronts
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
SuperDave
Yamaha RX-V992
Denon DVD-1920
Sony XBR 27"
BrightHouse DVR
Polk LSi25 Fronts
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
Denon DVD-1920
Mitsubishi 40" LCD
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
Post edited by SuperDave on
While the LSi9 does have a power port, I don't believe it is designed as a wall mount like the LSi7 or FX. I would actually prefer the LSiFX regardless for the bipole/dipole capability for movies.
Get the LsiFX.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I would go with the Lsi7's or Lsifx. The 9's can't be wall mounted not to mention there to damn deep.
The 7's make perfect rears . I liked them
DanDan
I thought the plate in the back of the 9's made them mountable. Thanks for the info. I thought that normal speakers would be a good choice over dedicated surrounds in case I changed configuration later on. I hardly ever see the 7's for sale on line. At least not as much as 9 or FX.
SuperDave
Yamaha RX-V992
Denon DVD-1920
Sony XBR 27"
BrightHouse DVR
Polk LSi25 Fronts
Polk LSiC Center
Infinity RS1 Rears
Monster THX CablesSuperDave
Denon DVD-1920
Mitsubishi 40" LCD
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
the plates do allow the 9 to be wall mounted, but it's kind of awkward. the LSi9 is a very deep speaker. the argument isnt wether it could be wall mounted, its wether it should. and cast my vote to know. I have the 9's as surrounds and wouldnt consider wall mounting it. they are on stands.
go 7's or lsifx for wall mounting. the 9's seem a little underutilized for surround duty anywayLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Wait- your 9's have a keyhole on the plate to wall mount them????
Why don't mine?Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
LsiFx better for movies and can be wall mounted.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
unc2701 wrote:Wait- your 9's have a keyhole on the plate to wall mount them????
Why don't mine?
the nine's do not have the keyhole, but supposedly, the powere port mounted to the back can be used as a mount, not sure how. to me the point is moot, the 9's are way too deep to not look retarded as a wall mountLiving Room 2 Channel -
ohskigod wrote:the nine's do not have the keyhole, but supposedly, the powere port mounted to the back can be used as a mount, not sure how. to me the point is moot, the 9's are way too deep to not look retarded as a wall mount
Don't attempt this. the speaker i to heavy for the mount to work. If you want rear, the 9's are not the way to go.
DanDan
