A little S&M
BobMcG
Quite the view outta your cabin huh?:)HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Isn't it?
It is the sunset at the North Pole with the moon at its closest point. And you also see the sun below the moon. -
OMG! That is beautiful!!!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Awesome!Michael
NORTH of 60° -
WOW That is beautiful.
JT -
anyone found a higher resolution pic?
Polkmaniac wrote:anyone found a higher resolution pic?
I'll see what I can do. -
Thanks Bob. A moment of bliss.
No dice. The guy I got it from had it emailed to him by a friend who got it from who knows where. I've searched for the original with no luck.
I found it... and it's undetermined whether as to it being real or done with the aid of a computer. I was originally told it is indeed real. Maybe not but it is Here -
It's a gorgeous picture, I actually set it as my wallpaper. Thanks for posting it.
It looks like it could have been made in a program called "Terragen", a landscape and scenery generator.
http://www.planetside.co.uk/terragen/
http://www.planetside.co.uk/terragen/gallery/gallerymain.php -
testing 123Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about. -
testing 456Jolida Tube
I like the pick but it has to be fake. The shadow on the moon that produces the cresent is cast by the earth. If both the sun and the moon are in the foreground the earth's shadow would not be present on the moon's surface.
Besides the size ratio of sun to moon is off. It is still sweet.:) -
daniel_paul_ wrote:I like the pick but it has to be fake. The shadow on the moon that produces the cresent is cast by the earth. If both the sun and the moon are in the foreground the earth's shadow would not be present on the moon's surface.
Besides the size ratio of sun to moon off. It is still sweet.:)
thank you, I was going to say photoshop but.....
it does look cool though.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
I think the water and mountains are in some 3-D modeling program.
