Cambridge audio 640C V1 Vs. Rotel 1072
cbl117
If you needed to choose between the Cambridge audio 640C and the Rotel 1072, what would you choose? and Why? I know the DACs are different, but is one DAC better than the other?
My budget is $500. I'm looking at the Rotel 1072 used. The cambridge is on sale at audioadvisor for $343. Are there any other CDPs that I should be looking at?
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Post edited by cbl117 on
Honestly...you would not be making a mistake which ever way you go. There was a thread here a few weeks ago where the 1072's praises were expanded on at length. The CA is also thought of very highly and has been discussed on the forum also. I've heard both and I like both. The Rotel may be a little better thus the $157 higher price. The CA is close and for $157 less you get a very good CDP with a mfg. warranty. Either way you go....you will be pleased."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Search for the thread on the Rotel shack mentioned. It received a lot of praise.
I would most definitely go with the Rotel.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
thanks for the replies. Unless I find a good deal on a used Rotel 1072, I'm going to go with the CA 640c.
I'm just trying to figure out if the 640c V2 is worth the extra cash. Is the only difference the DAC quantity? V1 has one DAC, while V2 has two DACs. Does this really matter in the real world or is it only gonna matter on spec sheets?
Oh I did read those threads you were speaking of. It just made my decision that much harder...;)2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Black Diamond Racing Isolation -
I have the Rotel 1072. I love it!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
There will be a real world difference between the 640C V1 and V2, for sure. The only question is are you a critical enough listener, and is your system up to snuff for that difference to be noticeable and appreciable.
If you're going to put out enough dough for the 640Cv2, I would really go with the Rotel instead.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
It probably matters...the question is how much and is it noticable in your rig. My guess would be not a lot.cbl117 wrote:I'm just trying to figure out if the 640c V2 is worth the extra cash. Is the only difference the DAC quantity? V1 has one DAC, while V2 has two DACs. Does this really matter in the real world or is it only gonna matter on spec sheets?"Just because youre offended doesnt mean youre right." - Ricky Gervais
cbl117 wrote:....I'm just trying to figure out if the 640c V2 is worth the extra cash. Is the only difference the DAC quantity? V1 has one DAC, while V2 has two DACs. Does this really matter in the real world or is it only gonna matter on spec sheets?....)
The 640C V2 also received a new transformer (quieter), control bus connections, dimming LCD panel.
Just FYI.
DaveHT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Dual Dac's is ALWAYS a good thing. If it's within your budget get the V2. The Rotel is a great choice as well.
+ 1 for the Rotel.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
I was checking out Rotel's website, and I think the Rotel 1072 only has one DAC. Could someone confirm that?2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
I *believe* that you're right on that. However, the number of DACs does not dictate sound quality.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote:I *believe* that you're right on that. However, the number of DACs does not dictate sound quality.
Uhmmmm. Yes and no. Sure 1 ultra-accurate single DAC may sound better than 2 mediocre DAC's. Obviously many other things are at work in the design. I'd bet, given that these two units are pretty similar to each other as far as design, pricing, packaging, etc., dual Dac's is the ticket. It isn't the end all, but here I think some people would notice and improvement.
But, again as I stated earlier, each is a soild choice.
I wasn't trying to say that the Rotel walks over the CA, I was just wanting to point out that single components, and lots of times even the whole thing, isn't very representative of how it will sound to you in your system.
The 640Cv2 and RCD1072 have similar designs? Didn't know that. Given that, and that the DACs are of similar quality, I'll bet that the CA probably would be better with two of 'em.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote:The 640Cv2 and RCD1072 have similar designs? Didn't know that. Given that, and that the DACs are of similar quality, I'll bet that the CA probably would be better with two of 'em.
Maybe similar design was the wrong word. But they are in the same league, comparable components, build-wise, budget wise, target market etc. One is not heads above the other. Maybe this makes more sense
. Typically if they incorporate 2 dac's generally there has been more care taken internally.
Which ever one sounds better to you, if you can compare them side-by-side.
Thanks for the clarification. Makes sense.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Thanks for the info!
I'll try and find a hifi shop around the LA area and give them both a listen. I'm leaning toward the CA 640C V2 since its the cheaper of the two. Unless there is a big difference between the two, the CA is my ticket.2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
50 Posts!!!!!!! I'M a POLKSTER NOW!!!:D
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Hehe...maybe now you're waist high to the proverbial 'CP grasshopper'...:p
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
The CA 640C won't play back HDCD...This was the only reason I did'nt get it instead of the Rotel 1072.
To most,this is not a big deal,but to me it was worth the little extra for the 1072.
Picked up our Rotel on the gon' for 500 shipped. -
Mike Reeter wrote:The CA 640C won't play back HDCD...This was the only reason I did'nt get it instead of the Rotel 1072.
I've been wanting to get the 1072 also. Hopefully soon. $500 shipped is a really good deal.
