bass traps-concrete forms
dholmes
Did anyone see the DIY home theater show a few months ago when they used concrete forms filled with sand as bass traps? From what Ive read, it wont work! Has anyone tried this? Also what about using the conrete forms, drill some holes in them & filling them with the pink insulation as bass traps, maybe raising them off the floor a bit & covering them with cloth. thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
can be made by taking rolled insulation in plastic covers, painting the rolls black and putting them in unabtrusive places in the corners.
I have some corners that are hidden by furniture, and don't have to worry about WAF, so no problem.
I guess you could cover them with cloth if they were more out in the open.
Trees -
I have tried placing insulation to see if it is effective - it is - but I have not tried to put it in a container. I just covered it with cloth. Two rolls corrected a dip at 100 hz n the opposite corner but I switched my sub placement and don't use them now.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
This link is your best bet for cylinder DIY bass traps:
http://www.geocities.com/jonrisch/basstrap.htm
construction explained in this link:
http://www.geocities.com/jonrisch/a1.htmSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I created a thread on tube traps that contains many links.
