bass traps-concrete forms
dholmes
dholmes Posts: 1,136
Did anyone see the DIY home theater show a few months ago when they used concrete forms filled with sand as bass traps? From what Ive read, it wont work! Has anyone tried this? Also what about using the conrete forms, drill some holes in them & filling them with the pink insulation as bass traps, maybe raising them off the floor a bit & covering them with cloth. thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • trees
    trees Posts: 71
    edited March 2006
    can be made by taking rolled insulation in plastic covers, painting the rolls black and putting them in unabtrusive places in the corners.
    I have some corners that are hidden by furniture, and don't have to worry about WAF, so no problem.
    I guess you could cover them with cloth if they were more out in the open.
    Trees
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2006
    I have tried placing insulation to see if it is effective - it is - but I have not tried to put it in a container. I just covered it with cloth. Two rolls corrected a dip at 100 hz n the opposite corner but I switched my sub placement and don't use them now.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • tryrrthg
    tryrrthg Posts: 1,896
    edited March 2006
    This link is your best bet for cylinder DIY bass traps:
    http://www.geocities.com/jonrisch/basstrap.htm
    construction explained in this link:
    http://www.geocities.com/jonrisch/a1.htm
  • jmierzur
    jmierzur Posts: 489
    edited March 2006
    I created a thread on tube traps that contains many links.
