svs sub
logos424
Hi:
I am looking at purchasing a 31+ or 39+ svs sub. Not sure which to get. I want nice tight bass for my music but I also want a 20Hz extension or lower for movies. I know I can tune both to 20Hz and lower but does anyone know which one will goes louder. I assume that the 31 can go louder and be tighter as it has the smaller encloser but I am wondering if it can give me that rumble factor I am looking for in movies. Still want it to slam me in the chest for music. Can't decide which I want more.
How I will probably set it up:
Probably set the cross over to 80or100Hz.
Room:
basement with 6" concrete floor with rug over it.
Front wall and left wall 6" concrete with insulation and dry wall.
back wall and right wall are just dry wall with no insulation.
Current setup follows:
Room:
Current Setup:
Main: Monitor 60 (bi-amped on my amp using the extra rear conections for 7.1)
Rear: Monitor 40
Center: Monitor CS1
Sub: SVS 20-39PC+
DVD: Sony DVP-NC675P (use 5 disc to play cds)
TV: Panasonic 32" Tau
Reciever: Marantz SR7500
Rear: Monitor 40
Center: Monitor CS1
Sub: SVS 20-39PC+
Post edited by logos424 on
The 31+ (with no ports plugged) is the volume champ of the plus line. (obviously for 25hz and above).
For music and movies - the 39+ is the best combo. (more volume than a 31+ plugged with a little deeper extension.)
If I wanted it for both movies and music, I would go with the 39+.
I do like my 31+ but still plan to upgrade to an ultra (or infinite baffle) sometime. If I go the Ultra route, it is based on the 39" size tube.
I have the 39+ it's set to 20hz and get be dropped down to 16hz with extra port blocker.
I have set the gain at 10 o'clock on the sub, and on the speaker config is set to +3db(avr).
Now I live on the 2nd floor of a 2 Family house so I have wood floors, The living room is 28x17x11 with open dinning room and kitchen areas.
I use my setup primarily for HT and the sound is Awsome, because I have it in a corner it travels and vibrates the surronding area. -
What if I purchased 2 PB10-ISD,s instead? Would I see more bass out of SVS's 2 10" powered subs instead of the 12" cylinder?
For those who don't know:
PB10-ISD specs (x2)
10" woofer
300w rms
+/- 3dB from 20-100hz anechoic
weight = 60 lbs.
or
20-39 PC Plus
12" woofer
525w rms
+/- 3dB 20-100hz (20hz config) quasi-anechoic (can be tunned down to 12Hz I think)
Weight = 55 lbs.
or
25-31 PC Plus
12" woofer
525w rms
/- 3dB 25-100hz (25hz config) quasi-anechoic (can be tunned down to 16Hz i think)
Weight = 51 lbs.Current Setup:
Rear: Monitor 40
Center: Monitor CS1
Sub: SVS 20-39PC+
Reciever: Marantz SR7500 -
I myself have the 39+ and I find I have a deep rich base for both movies and music. I have it set for 20hz. My house is built on a slab in Fl. and my room is about 16x20. I was indeed impressed with the bass sound for music. I to would go with the 39+. DougOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Anyone ever have any chuffing/farting problems with the pb or the cylinder subs. Nothing p****** me off like hearing that when I am watching a moving or listening to music. My Polk PW10 does it all the time.Current Setup:
Rear: Monitor 40
Center: Monitor CS1
Sub: SVS 20-39PC+
Can't say I have heard any of those sounds you subscribed. Mine has been aok.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Comes from the ports on the sub as the driver is pushing to much air for the enclosure.Current Setup:
Rear: Monitor 40
Center: Monitor CS1
Sub: SVS 20-39PC+
I would hesitate to recommend any specific sub for you as you have not mentioned the size of the room in question, nor your listening preference (db level).
If you are seriously considering an SVS, send the folks at SVS an email describing your listening habits, room size, room construction, budget etc. with as much detail as possible. They should be able to help you with your selection of sub. -
Tried that just wondering what other people thought before I drop a G note on anything.
Here is my room basically:
XXXXXXXXXXXXXXXXXX
X X X
XXXX X X
X X
X X
X X
XXXXX XXXXXXXXX
14' x 20' x7'
Materials of the room are at the top of the emailCurrent Setup:
Rear: Monitor 40
Center: Monitor CS1
Sub: SVS 20-39PC+
crap! sketch didn't go through. Lets just say it is rectangular with a small storage room on one end and a 4.5' opening on one side towards the back.Current Setup:
Rear: Monitor 40
Center: Monitor CS1
Sub: SVS 20-39PC+
logos424 wrote:Tried that just wondering what other people thought before I drop a G note on anything.
Tried what? Contacting SVS?
When I composed this reply quoting your message, the 'outline' of the room appeared correct.
Considering your room size, planned use (music and movies) and provided selection, I would opt for the 20-39 PC-Plus. -
Yeah, that's what I meant. Just thought I would check here and see what other people thought. I don't totally trust the opinion of anyone trying to sell me and then their recomendation is an upsell. I am not saying that the guys at svs aren't turstworthy I just want a second opionion, and a third, fourth, fith, sixth,:p
Current Setup:
Rear: Monitor 40
Center: Monitor CS1
Sub: SVS 20-39PC+
If you have a small closet in your room, you might want to try an infinite baffle subwoofer.
logos424 wrote:Yeah, that's what I meant. Just thought I would check here and see what other people thought. I don't totally trust the opinion of anyone trying to sell me and then their recomendation is an upsell. I am not saying that the guys at svs aren't turstworthy I just want a second opionion, and a third, fourth, fith, sixth,:p
Actually, they were fairly persistent in trying to down sell me when I contacted them regarding the purchase of two 20-39 PC-Plus subs for my room. Then I totally surprised them by deciding to purchase two PC-Ultra's. They know their product well and recommend accordingly.
Have a look at the Home Theater Spot, SVS board for more info on SVS subs. -
My pb10 never farts or chuffs. Just solid, deep, room-shaking bass that pisses off my wife, but my son & I love.logos424 wrote:Anyone ever have any chuffing/farting problems with the pb or the cylinder subs. Nothing p****** me off like hearing that when I am watching a moving or listening to music. My Polk PW10 does it all the time.bms
Family Room:
Onkyo TX-RZ920
Outlaw 2200 monoblock amps x 3
Sony UBP-X700
Sony A80J 77” OLED
Polk LSiM 705’s
Polk LSiM 706
Polk LSiM 703’s
Polk RTi4's
Dual SVS PB13-Ultra’s
PC13-Ultra
Bonus Room:
Onkyo TX-SR806
PS3
Panasonic TC-P42G10
Polk RTi10's
Polk CSi5
Polk R50's
SVS PB10-ISD
For sale:
Onkyo TX-SR603X -
I had some chuffing with my old PC + during WOTW with my sub calibrated at about 2db hot.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
