Calling all guru's !
noisy
noisy Posts: 3
edited March 2006 in Speakers
Can you help me identify this center? I purchased it in mid 1995 along with my 10's which I am using for my fronts. I have 2 M3's that I use for my rears...I obviously need more power for my rear...front is a bit heavy :D Anyhow, the sticker came off this from the heat of my big screen that it sat on, and for the life of me I cannot remember the model. Any help you can give is greatly appreciated.
The (4) mid's had a sticker on them that said MW4850 and they are 5" ea.
The tweeter is a tri-lam 3 1/2"
The dimensions are 26" w x 10.5" d x 6.5" h
Thanks in advance if you can help !!
WILL WORK FOR POLK's!!
Post edited by noisy on
  • TroyD
    TroyD Posts: 13,124
    edited March 2006
    CS 350LS, pretty sure.
    BDT
  • noisy
    noisy Posts: 3
    edited March 2006
    jeeeeeeez...you guys are fast...was uploading the pics, and you were done before I could get em up!
    Thanks !!!
  • fireshoes
    fireshoes Posts: 3,167
    edited March 2006
    Good thing there was a guru logged in. :)
  • Polk65
    Polk65 Posts: 1,405
    edited March 2006
    That's no joke. It's amazing how guru's appear out of thin air when you mention them. Imagine my surprise after typing a response and seeing BDT beat me to it. Ah well, I guess we have no chance until we get our own magic carpets. :D
  • bassaholic
    bassaholic Posts: 315
    edited March 2006
    are you serious! what a ****
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
  • TroyD
    TroyD Posts: 13,124
    edited March 2006
    Oh, wait, you are a newbie. I'm supposed to be an **** and run you off. What's wrong with me??
    Welcome and enjoy, that's a nice center!
    BDT
  • Willow
    Willow Posts: 11,218
    edited March 2006
    BDT
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2006
    Noisy, Welcome. That is one massive center channel! Me like.:D
    Bassaholic, I don't know what your problem is, but that was uncalled for!
    Go back to bed & try waking up on the right side of it!:rolleyes:
  • hoosier21
    hoosier21 Posts: 4,415
    edited March 2006
    I would have answered this, but I am not a Guru :(
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2006
    Looks like the dampening material is blocking one of your ports, I dont believe that is the way its designed as air should move from it, may have shifted try moving it a bit and see if the speaker will not play down a bit deeper.
    RT1
  • noisy
    noisy Posts: 3
    edited March 2006
    Thanks for the welcome...I am a happy poster at many forums so am used to the "****" statements...always happens. We can't ALL be as thmawt ath you Bassaholic..but thomeday maybe...lol
    I have it set up with my 10's as the fronts...any recommends on a good rear set to go with this? I have some little M3's on the wall...but obviously the front TOTALLY overpowers these.
    Thanks reel for the advice, I will do that immediately and check the difference.
    Peace All
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2006
    That's a monster center! Welcome:)
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Polk65
    Polk65 Posts: 1,405
    edited March 2006
    Can you adjust the channel volume with your receiver/processor? If you are able to get the M3's volume to closer match the front and center, this option won't cost anything. The M3's can handle 100w and do a good job as surrounds. Do you have a subwoofer?
    If you decide that you want new surrounds, you have many options. Have a look through this HT guide and let us know which type you are thinking of. http://www.polkaudio.com/downloads/hthandbook.pdf More here: http://www.polkaudio.com/education/index.php
    * mounted flush in the wall?
    * wall mounted small speakers?
    * a bookshelf speaker on a pedestal?
    * a floor standing speaker that is tall and narrow?
    * a speaker that is wide and short (like your Monitor 10's)?
    BDT
    Troy, dump the sugar substitute labeled "PC" next to the coffee.
    Bassaholic, not too long ago you would have been keelhauled for a comment like that. Get used to the fact that not everyone spits out a direct answer, some have humor, and others are trying. If you don't like it, change the channel.
  • Polk65
    Polk65 Posts: 1,405
    edited March 2006
    What are you using to power all of this? If it's a receiver, some of them send less power to surrounds.
