Changing Amplifiers Binding Posts
DiscoMike
DiscoMike Posts: 114
edited March 2010 in DIY, Mods & Tweaks
I have an Onkyo Integra M-504 Power Amplifier which uses cheap plastic binding posts. This limits the use to using a bare wire going into the amp. Anyone who owns (or had owned) this amp knows exactly what I mean. For a power amp of this caliber, its a shame to see Onkyo skimp on the speaker connections.
Does anyone have any advice on what are pretty good binding posts to replace on these amps ? I want something that sounds full and lifelike.
Any recommendations are greatly appreciated.
Thanks much !!!
Disco Mike
Post edited by DiscoMike on
  • dorokusai
    dorokusai Posts: 25,640
    edited February 2006
  • zingo
    zingo Posts: 11,258
    edited March 2006
    I have the same problem with my Hardon/Kardon amp. It had the screw type wire connectors, but the hole in the middle does not do all the way through, so banana clips cannot be used. Not cool man, not cool.
    Oh the things we get upset over...
  • Modvlar
    Modvlar Posts: 51
    edited March 2006
    Hi,
    Can you make a breakout box? If you can remove the binding posts, throw some rubber grommits around the holes to protect the wires feeding through, then directly feed the outputs into a small external unit that you can put better sockets on. Poof! Nice if you can also design them to be removable, (ie. put a junction between the amp and the box, depending on how audiophilic you wanna be).
  • unc2701
    unc2701 Posts: 3,587
    edited March 2006
    I've had good luck with WBT... and heard good things about vampire wire.
    whoa! old thread.
    Backburner:Krell KAV-300i
  • dorokusai
    edited March 2006
    Modvlar wrote:
    Hi,
    You certainly can, but why? My experience with binding post and RCA replacement has shown that the wires and sub-assemblies, for those parts, are often not very long in the first place. I think a removeable junction box, for your everyday speaker is an even worse idea. However, if you DIY, removeable and hot swap capable assemblies make all the sense in the world.
    If you're going to do it, just replace the stock binders with something of quality and be done with it. Unless it's a vintage piece of gear, it should only help with resale and be a positive upgrade.
    Good luck.
  • Peabody67GTO
    Peabody67GTO Posts: 25
    edited March 2010
    Hi,
    I have the same issue with my 504 but cannot find any binding posts made for a AMP. The 4 factory BP can be removed with no problem but I just find single BP and not 4 in a set like they are on the back of the amp.
    Any idea where I can get 4 BP together?
    THANKS
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2010
    Any decent electronics store sells good 5-way binding posts.
    http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=107&CFID=6048448&CFTOKEN=76550411
    Remove your old ones. Make sure that the new one fit in the hole. Install the new ones. Solder the connections/wires, and you're done. Very easy to do.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
