HT Guys I need a little clarification
heiney9
heiney9 Posts: 25,408
edited March 2006 in Electronics
Being as I'm a 2-channel guy and my knowledge of HT is somewhat limited because I don't follow it as closely as some. I have a question. Many movie DVD's that are being released don't always have a seperate 2.0 track to choose from. I'm finding lately that it's either 5.1 DD or 5.1 DTS. Of course I have to choose 5.1 DD. What's going on here? How are 5.1 channels being blended to a 2.0 channel system.
Certain sounds seem to be recessed a bit, but at the same time things give the illusion of being more spread out. It seems to work fine and I don't have to strain to hear anything. But I want to understand what's going on because I am curious.
Post edited by heiney9 on
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2006
    I would guess your processor would send the center channel data to both L and R, and all left-side data (front and rear) would go to L, and all right-side data (front and rear) would go to R.
    edited March 2006
    Makes sense. I don't have a processor. The DVDp is hooked thru the analog outs (R, L) to the Aux in on my preamp. I guess the processing chip in the DVDp would blend it. Still wondering exactly what's going on here.
    edited March 2006
    Just to clarify. The DVDp I have is older and it only has analog outs (R, L) and a digital coax and optical out. No processing takes place with the DVDp. I'm running digital coax to my DAC and then out of the DAC into the Aux on my pre. It appears no processing is taking place.
  • peteran
    peteran Posts: 141
    edited March 2006
    probably your player is defaulting to PCM instead of direct digital.
    edited March 2006
    Ok, again makes sense. Maybe you can answer this, why is it when on other DVD's which have a 2.0 setting, that setting sounds different than the 5.1 DD setting. Both should be PCM if the player is defaulting to PCM in 5.1 DD mode :confused: .
  • Ricardo
    Ricardo Posts: 10,636
    edited March 2006
    H9,
    All I can say is, get a 5.1 system and enjoy the movies as the are supposed to sound...
    *leaning back waiting for the punch*
    SOPA
    edited March 2006
    HTrookie wrote:
    H9,
    *clenches fist, **** arm back, pushes arm forward, stops right before HTrookie's shoulder and gently taps him* That didn't hurt did it?:p .
    Someday when I have enough space to build a dedicated, well designed 2-ch room then I can set-up a modest HT where my system is now. Right now it's just not that important to me. I was just wondering what's going on w/ playing 5.1 DD output thru a 2-ch system.
  • Skynut
    Skynut Posts: 2,967
    edited March 2006
    HTrookie wrote:
    H9,
    I must agree, movies are just better on a good surround system.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • adam2434
    adam2434 Posts: 995
    edited March 2006
    A couple things could be happening there.
    1) Sometimes the 2.0 is an uncompressed LPCM track, sometimes at a higher bit depth than standard redbook CDs. For example, I have some concert DVDs that have a 20 bit LPCM stereo track. The 5.1 soundtrack will be DD or DTS, which are compressed formats.
    2) A 2.0 soundtrack (whether LPCM or DD) mixed by the engineer will not necessarily be the same as the 2.0 soundtrack that is downmixed in your DVD player from the original 5.1 soundtrack. Sure, your DVD player is converting both to PCM (assuming you have set the DVD player up to do that), but they do not necessarily have the same info/mix. Essentially, one was mixed by the engineer and one was mixed by your DVD player.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • unc2701
    unc2701 Posts: 3,587
    edited March 2006
    If there's not a 2.0 track, most players downmix the 5.1 into matrix dolby surround and dump this via PCM. So w/ 2.0 you get the sound engineer's mix (usually matrix dolby, but possibly different from the original 5.1) w/0 2.0, you get the same data as the 5.1, just matrixed.
    edit: ok, that's twice today I've taken too long and posted about the same thing as the guy above me.
    Backburner:Krell KAV-300i
    edited March 2006
    That makes the most sense. It seems we are at the mercy of the person who mixes the audio. I have noticed a great degree of variation on music DVD's. Some seem to sound incredible others are just ok, in the 2.0 setting. I mainly own music DVD's and the differences between all of them are quite apparent. I actually sold a DVD I had because it had no 2.0 option and 5.1 DD option sounded horrible in 2-ch. Why can't they just make a typical 2.0 PCM track mixed for 2-ch. It can't be that hard, I know that's not what the masses want, but it's what I want :mad:.
  • mldennison
    mldennison Posts: 307
    edited March 2006
    sorry, dont think you are going to be getting that anytime soon, the number of people running 2 ch HT that can hear a difference (not just through the tv speakers) is not going to justify the space on the disc for an extra soundtrack. guess you will just have to run out and buy a HTIB :p
  • adam2434
    adam2434 Posts: 995
    edited March 2006
    Yeah, DVD's audio recording/mixing/mastering/transfer quality is all over the map, same as other audio media. If the original recording was bad, the 5.1 would be bad, and so would a 2.0 downmixed from it.
    How a recording is mixed and transferred to DD or DTS is a factor too. For example, the 5.1 mix of one of my Stevie Ray Vaughn DVDs is horrible, but the 2.0 is much better. The 5.1 is hollow and compressed - unlistenable.
    edited March 2006
    Which SRV DVD? From memory they all sound vg/ex on the 2.0 tracks.
    Yeah, Yeah...that's hoping for alot. It seems pretty basic to me to mixdown a nice sounding 2.0 track. It certainly wouldn't take up much space, especially on music DVD. Movie DVD's with all the extra's, I could see that maybe being a problem. Quasi, mixed-down, hastily mixed, DVD's still sound loads better on my 2.0 ch than on a HTiB ;):) . So I'll make due with what I have for now!!
  • adam2434
    adam2434 Posts: 995
    edited March 2006
    I think it was the 5.1 from El Mocambo (sp?) that sucked so bad, with the 2.0 being much better.
    There's another one that I think sounds better in 2.0 - Neil Young's Black and Gold.
    For the rest, I prefer the 5.1 mix.
  • Drumingman
    Drumingman Posts: 348
    edited March 2006
    Yeah Yeah Yeah A HTIB would work great for you.
    Be sure to get the cute little cubes.
