timbre matching
jeremie
jeremie Posts: 246
edited March 2006 in Speakers
is it important to have all the speakers the same in a 7.1 setup. Reason i ask is that i am thinking of doing a 7.1 with (5)LC265i and 2 Niles inwall FX speakers. I know the tweaters are different but was curious if that would make a difference since it is side affect? Also is it ok to have the center vertical vs. Horizontal?
Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
Post edited by jeremie on
  • Willow
    Willow Posts: 11,228
    edited March 2006
    It's not set in stone but is a good rule of thumb to have all speakers timbre matched.
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    You're OK as long as the front soundstage matches.
    "God grooves with tubes."
  • aaharvel
    aaharvel Posts: 4,489
    edited March 2006
    the back surrounds i've found to not be as important for EXACT timbre; but still get as close as you can.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
