Do I need an amp for my LSi9's?
Ised8u
Ised8u Posts: 20
edited March 2006 in Speakers
Okay, I just sold my New In The Box CSi5 on ebay and had to eat about $40 bucks..not too bad. StopherJJ1980 good idea on the "Buy it now" thanks! I apologize if I were a bit over zealous with trying to sell it here on CP, I really didn't know the proper etiquette and I really needed to sell the CS before I could buy the LSiC. I do appreciate everyone who had constructive critisim to give me regarding the topic. Okay, enough of that. I am still in the same boat with my receiver. Right now I have a Yamaha HTR 5990 to go with my current speakers.
Lsi9's front
Lsi-C center (on the way)
Lc 80i rear ceiling
Psw 1000 sub
Several members suggested keeping the HTR 5990 and perhaps using it as a preamp.
question? What brand/ model of amp would be good to drive those Lsi9's and perhaps the center channel as well.
Or would a more powerful rated receiver be a better route??? name and brand would be appreciated.
People who think they know everything, really annoy those of us who do.
Post edited by Ised8u on
  • michael_w
    michael_w Posts: 2,813
    edited December 2005
    I would say stick with the yamaha and use it as a preamp. I'm not really sure on what amp would go well with the 9's, but people around here seem to go with brands like outlaw (the $200 monoblocks are popular), nad, rotel, adcom and some others. I'd think that trying to go the seperates route would be better but might be a bit heavier on your wallet (unless you stick with the yamaha as a pre/pro).
    Hope that helps a little...
  • jgladden
    jgladden Posts: 7
    I bought the Adcom 5 channel model 7000 used. Haven't had anymore problems. The Yamaha works fine as a pre-amp.
    Jgladden
    Yamaha RX V2200
    Adcom 7000
    Polk LSiC
    Polk LSi9
    Polk 404 Sub
    Polk LSIFX
    Sony 55" LCD HDTV
  • cfrizz
    cfrizz Posts: 13,415
    Congrats. Outlaw, Rotel, Parasound, ect. All are good. If you can swing a 5-7 channel amp that would be best since then you would be totally covered & it would save you from upgraditis for more later on! Maybe! LOL
    Whatever amp you get, you should not get less than 200 watts!
  • jimithng23
    jimithng23 Posts: 48
    edited March 2006
    Lsi9's front
    Lc 80i rear ceiling
    Psw 1000 sub
    if you want to stay with the receiver option i HIGHLY recommend the yamaha rxv2600. the htr line that you bought is the "b" line yamaha product, while the "rxv" is the main line. think toyota/lexus. this receiver has many great features, MORE than enough power to drive your lsi system, and while others may recommend the amp/preamp solution, this may be cheaper and you yourself may not be able to tell the difference. i guess it all depends on what you can get back from the 5990. check my sig for what i am running and it performs VERY well. i get compliments all the time on how good everything sounds. the room i have it setup in is about 20 wide by 12 deep. not too big and the system does an awesome job.
    Jeff Rowland CAPRI | Yamaha RX-V3800 | Jeff Rowland Model 6 Mono Blocs | Technics SL1200 MKII | Shure V15VxMR w/ JICO Stylus | Sony SCD-XA5400ES | Monster HTS 2600 | Polk Audio LSi 15 w/VR3 Fortress Mod | REL T/9 x2
  • ohskigod
    ohskigod Posts: 6,505
    edited March 2006
    at least get amplification to the 9's to start if the budget is tight. can go with used 2 channel amps (assuming that reciever has pre outs.)
    As mentioned, the outlaw mono's seem to be a great bang for the buck. 325 each new 300 watts into 4 ohms, not shabby. I will be getting 2 of them used and will post my impressions down the road.
    I am a personal fan of Rotel amplification, but there are a lot of parasound lovers out there too. just some names, especially if you go the used route. Try to shoot for AT LEAST 200 wpc into 4 ohms. lots of used listings only have the 8 ohm rating, but if you search online or check with us, you can get the 4 ohm ratings.
    for example, I have a Rotel RB980 that is 120 WPC into 8 ohms, but 200 WPC into 4 ohms.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • doggie750
    doggie750 Posts: 1,160
    edited March 2006
    Amplified it............
    I suggest Carver amps.........for a tight buget
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2006
    I agree with the whole 'don't go under 200w idea.'
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Lsi9
    Lsi9 Posts: 616
    edited March 2006
    Those Outlaw monoblocks are $325...I am considering getting 2
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
